Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 06-24-2008, 07:42 PM
KustomKoncepts is on a distinguished road
Z zero question
using V carve I have a bunch of circles that are to have a finished thickness of .78" I am using 1" walnut boards but they can be inconsistant and I have may change outs to do.
what I want to know is if there is a way to set the z zero at the bottom (I know how to set that in v carve) but after that I want to tell it to make a bunch of different cuts .78 .655 .25 ect can v carve think upside down from bottom to top from the z zero or do you have to use the depths from the top down?
Old 06-24-2008, 08:09 PM
cabnet636 is on a distinguished road
hey kustom
isn't it in the sequence of the tool paths?
jim
Old 06-24-2008, 08:30 PM
I don't know. I may have 10,000 4" circle things to cut with veryiing cuts in it but find 477 5" x 96" boards that will be the same thickness. I thought I cout reverse it from the bottom up or I will have to buy a board plainer to get them flat, straight and the same thickness.
Old 06-24-2008, 09:56 PM
off to bed
what type of wood ?
jim
Old 06-24-2008, 11:08 PM
black walnut
also walnut fuzzes really bad and splinters have you cut it before?
Old 06-24-2008, 11:32 PM
ro7all is on a distinguished road
planer
save yourself a lot of grieve and buy yourself a 12 inch planner from dewalt or something equal to it and and a extra set of blades . that is a lot of boards !!! you should be able to get/ request your supplier to send them to pretty close to the finish size that you want . your planer will just give that final finish.
Old 06-25-2008, 10:44 AM
That is good info. here is my other problem though I think I got it figured out kinda. These also need to have a 7 DEGREE angle cut to them on the outside cut. Obviously a dove tail or stair stringer bit is 7 DEG and I found one 7/8 long. but is there a easier way to make a LEAD-IN? if the bit plunges straight it will clip the edge where it plunges in and out so I made a path so it cuts past and moves out to plunge but can I set a plunge point? in v carve I also have visual mill if that program may be better at this type of work. Thanks
I know these are more Program questions and not about the cnc's but I figure you all have had similar problems/ projects
Old 06-25-2008, 12:39 PM
ger21's Avatar
You can easily add lead in's in Vcarve by checking the "lead-in" box.
Old 06-25-2008, 01:20 PM
where is that. I will go into the program and look for it. thanx
Old 06-25-2008, 01:23 PM
Dumb. I found it Garry under the add tabs menu
you would hav laughed if you knew how I was trying to do that. that is pretty easy with the program. Thanks again for showing me that.
  #11   Ban this user!
Old 06-25-2008, 01:33 PM
to show what I was doing.
here they want a 7 Degree angle cut out in a 3.75 circle so I need a lead so the bit does not nip the edge where it plunges since the dovetail bit is fatter at the bottom VS the top side of the bit.
Old 06-25-2008, 03:26 PM
HuFlungDung's Avatar
Moderator
If I understand your original question, I think you should be able to accomodate different material thicknesses with your Z work offset.
You can still position the part in V-carve in a conventional manner, with Z0 at the top..
Then, set your tool length offsets relative to the bottom location of your stock. Then, if your current work offset is most likely G54 Z0, adjust it upwards by the amount of the stock thickness. No need to repost for different material thickness whatsoever.
