Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 06-16-2008, 06:29 PM
carving123 is on a distinguished road
Unhappy Error on Fagor 8055
Can anyone help me figure out how to fix "1102 X Axis following Error" ???
Old 06-16-2008, 06:45 PM
Al_The_Man's Avatar
Following error is generally the axis cannot keep up with the commanded move, is the axis moving? Does it Jump suddenly or not move at all?
Do you have 'Following Error Display' screen on this model ?
Old 06-17-2008, 07:34 AM
The axis, In this case "X", will stop in the middle of a program. I will get the error message and will have to reboot the machine to get the axis to move. Last night i adjusted the transformer on that axis and was able to finish a program with out a problem. I am still unsure if i resolved the problem. What should the following error be set at? I am set at .0293 right now.
Old 06-17-2008, 09:07 AM
Al_The_Man's Avatar
Is this the set value or the reading of the Detected amount of FE?
The degree of setting amount will depend a lot on the type of machine and the tuning.
Test for tightness if it occurs at one spot etc.
You could increase the allowed following error value or try tuning the axis with a slightly more gain.
Old 06-17-2008, 11:02 AM
SCRAPWOTSCRAP is on a distinguished road
Maintenance???
MotionMaster and Western CNC use Fagor 8055, if your machine is one of these it may be wise to remove the ball screw cover and check the ball screw. Have seen this error on these machines when they are in dire need of cleaning, grease.....etc. X axis on these machines require weekly maintenance. Check belts, ball nut etc.
Old 06-17-2008, 07:16 PM
cam1 is on a distinguished road
The following error is not "set" ideally the following error would be 0, however that's not possible. Any time a machine starts to fault out on this kind of parameter, you need to check the basics (loose wires, etc.), before jumping in to the parameter table.Software doesn't just change. Mechanical stuff does.
Have a read...
http://www.fagor-automation.com/CNC/...Axis_Setup.pdf
PS write down the old values before making changes, and change 1 parameter at a time.
cheers
Can't Fix Stupid
Old 06-17-2008, 07:21 PM
More info....
cheers
Can't Fix Stupid
Old 06-17-2008, 08:15 PM
Al_The_Man's Avatar
I did not mean that the following error is set, I was referring to the following error Value that is allowed to occur before excess following error is detected and acted on.
Old 06-18-2008, 03:41 PM
Hi Al: I was referring to the comment by carving 123 that you quoted.
regards
Can't Fix Stupid
Old 06-19-2008, 07:52 AM
Thanks, You were very helpful. Problem solved!!
  #11   Ban this user!
Old 06-19-2008, 11:17 AM
Curiousity.......what was the solution?
  #12   Ban this user!
Old 06-19-2008, 05:26 PM
Tightened all the wire conections and clean and lubed all guide bearings and cleaned both lead screws. No problems since.
Fagor 8055 or Haas CNC control? Angry Man Fagor Automation 19 07-08-2011 09:04 PM
Problem- Post fagor 8055 for cimatron E Eurico Post Processor Files 2 11-21-2009 02:26 PM
Need Pos to WorkNc to fagor 8055. SOS!!!! xpisca Post Processor Files 1 06-26-2008 03:35 PM
Need Help!- Fagor 8055 Mill won't home cam1 CNC Machining Centers 12 03-04-2008 07:39 PM
Fagor 8055 power down/switch off smoregrava Fagor Automation 1 01-02-2006 06:32 AM
