Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 05-12-2008, 11:50 AM
Jerry In Maine is on a distinguished road
Belt Drive
I'm building the SolSylva Belt Drive wood router - or at least something close to it. Using the plans as a general guide, except I strengthening some of the Y & Z parts to avoid flexing - mostly by using steel in some areas instead of aluminum. This makes the Y & Z heavier, of course - maybe by a little more than 25%.
I've made a couple CNC wood routers before but have always used lead screws and have no experience with belts. I'm concerned if the additional weight is going to adversely affect performance - other than perhaps me having to adjust my acceleration/deceleration values/speed values a little
Out of curiosity - and I realize that this is a very general question: Are there "heavy" industrial routers that commonly use belts? The first machine I built was the first one IO had ever saw so I have nothing to compare with and nothing to do but ask.
Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? pfeist General Metal Working Machines 11 02-13-2012 02:12 AM
Need Sherline Belt & qestion on X2 Belt Drive? Oldboy Benchtop Machines 12 03-06-2008 12:42 AM
X3 Belt Drive? pzzamakr1980 Benchtop Machines 16 11-14-2007 10:15 PM
Belt Drive help bearwen Linear and Rotary Motion 5 10-31-2007 03:55 PM
X1 Belt Drive? Tag1260 Benchtop Machines 12 08-31-2007 05:38 PM
