Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 04-21-2008, 10:39 AM
desman is on a distinguished road
Cross between CNC Milling Machine and CNC Router
We make plastic and high density foam parts for aircraft interiors. We currently are running a couple of Shopbots and an old Bridgeport milling machine(Boss9 R2E4). The tolerance level of the Shopbots is acceptable for the parts they make. The milling machine works fine but we are needing to get into more speed and more size than it can run.
What we would like to do is have a machine that has the speed of a router but we also need the accuracy of the tolerance level of a milling machine. We do not need the 4x8 size of a router but we need more size than the Bridgeport which is 15" on the y axis.
Any suggestions for manufacturers that make 4'x4' routers/milling machines with tool changers.
Alan
Old 04-26-2008, 09:47 PM
Drassk is on a distinguished road
Forest Scientific can make a really accurate router. MultiCAM makes relatively accurate machines in their top line (MT or somesuch). If you need super accuracy and speed, then you're going to have to dish out for a VMC with a big table and it isn't going to be cheap (Haas makes some with 30K spindles now)
CNC Milling Vs CNC Router? RZA'77 DIY-CNC Router Table Machines 4 03-29-2008 06:22 PM
Need Help!- Milling or Router davidprice35 General Metal Working Machines 0 03-17-2008 07:23 AM
DIY 3axis router milling machine pinemartin CNC Wood Router Project Log 18 05-23-2007 12:50 PM
screw slotting and other ideas for a cross slide milling table scott m General Metalwork Discussion 5 12-20-2004 08:32 AM
Router milling Siress General Metal Working Machines 3 05-06-2004 05:14 PM
