| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
Anyone know anything about this router, I'm looking for an entry level router that can cut wood, polycarbonate and 1/8" aluminum. http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=015 Thanks for any info |
get 10 times the value http://www.romaxxcnc.com/ http://www.cnczone.com/forums/showth...t=50224&page=2 further you could go to a boating store and get hdpe get a set of joes cnc plans from this forum and build it for a lot less http://www.cnczone.com/forums/forumd...prune=-1&f=346 |
Is the romaxx capable of cutting 1/8" aluminum, I don't mind if it's slow. |
has these in all sizes i have a friend in columbis sc who has ordered a 3x6 for cutting a specific parts for his application price 8000.00 this one on website can run 7200.00 http://www.camaster.com/portal/Produ...4/Default.aspx the one below is equiped with 4rth axis |
| The mastersCNC is made of HDPE and is very well built. It is not made out of particle board as KustomKoncepts suggests (did you even READ the link?) I bought one and I don't regret it. I use it to cut brass, aluminum, and to do wood engravings using VCarve and 3DMachinist. Entry level? Yep. Underpowered? Yep. The thing is substantially cheaper than other options and is certainly less hassle than building your own. |
| I'm looking for entry level, I'm starting something and I don't want a high entry level cost, the pieces I cut never exceed 24"s. I cut mainly parts from polycarbonate and some aluminum. The aluminum is very simple cuts, straight and fluid curves with holes drilled. If this works out I would like to get a larger Router for other jobs and even later a CNC mill and lathe, but that's way down the line. I need to get my feet wet first before I spend serious money. I was hoping someone either had the Masters machine or could look over the listing and let me know their opinions. I do appreciate the links and will look into the Romaxx, it appears to be very nice. Thanks hualon I appreciate the input and I knew it wasn't particle board, I just choose to ignore that post. |
| Newbie- Does anyone own a EZ Router Machine? Plasma or Router. | sngatlanta | Commercial CNC Wood Routers | 30 | 04-11-2008 10:48 AM |
| Router Using 3/4" MDF (first router build) | eguy208 | CNC Wood Router Project Log | 33 | 04-11-2008 10:33 AM |
| Using a router for the 1st time. Need advice of cut speeds, router bits etc. | Apples | DIY-CNC Router Table Machines | 19 | 09-23-2006 03:33 PM |
| Surfcam PP for Isel router / Precix router | IvanTochev | Post Processor Files | 2 | 05-12-2004 12:27 PM |
