Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 01-30-2008, 05:49 PM
jallitt is on a distinguished road
Liyu router HPGL and RS232
Just picked up an oldish (2003) Liyu CNC router (model LE-5032 or SGJD5232). No software (but there are a couple of unmarked dongles) and the manual is in chinese . The dongles could be for type3 or bitcam.
The builtin test file runs OK and the spindle starts up when I send it a HPGL file via serial cable but I get no xyz motion. I think the spindle starts as soon as data shows up on the serial port though i.e it's not controlled by the incoming HPGL code. I also tried generic g-code but from what I can gather from the manual it requires HPGL or DMPL.
I just relocated a PC with a "real" serial port next to the machine to make sure it's not a usb-serial cable issue but still no luck. Maybe it doesn't like my HPGL (or it could be waiting for a specific init code). I'm going to try a 25pin parallel cable anf sending to LPT1: next.
Anyone know what HPGL should look like for one of these machines?
Old 01-31-2008, 04:32 AM
After much trial and error, random googling for english word combos in the printed manual and google translate of chinese manual pages I seem to have got HPGL into the router. As I suspected it needed some specific init codes.
I'm not 100% sure the scale is correct yet but I can change that easily enough the post-processor.
Next I have to hook up the water cooling for the spindle and see if I can cut something.
HPGL engraver. WilDun Machines running Mach Software 2 10-26-2009 12:11 AM
Importing a DXF or HPGL file wantsout Kellyware CAM 2 10-10-2007 04:54 AM
HPGL help me! vacpress Printing, Scanners, Vinyl cutting and Plotters 2 01-09-2006 04:49 AM
HPGL or PLT Creator tburkard General CAM Discussion 2 11-28-2005 04:15 PM
hpgl and stepper moter control Jan General CAM Discussion 1 01-08-2004 01:00 PM
