Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 01-29-2008, 02:11 AM
eng_semsem1980 is on a distinguished road
Biesse rover
Dear sir /Madam,
I have Biesse Rover 342 CNC machine and need Soft ware desks (Machine, PLC, Language, etc) because the all data lost ,we try to contact Biesse but not response from him so can any one support me by sent the soft ware disks?
Old 02-02-2009, 12:44 AM
knap is on a distinguished road
try to send an email to Biesse Service and quote them the serial number of your machine...
Old 02-16-2009, 05:13 AM
Mario B is on a distinguished road
Biesse Rover 322 Datatransfer problem
Hi there,
I know the problem with Biesse. they only want to sell new machines...
I have a Biesse Rover 322 and asked them if it was possible to connect my CNC to a PC. I have to program line for line in my workshop.
I'd like to do this on my desk with a PC, but it's not possible they say. Buy a new one... Even in Italy they don't respond to e-mail...
Is there enyone that can tell me if it is possible to connect my Biesse to a PC cause I don't believe a word they say.
I'm new in this but I can see an X-ax, Y-ax and a Z-ax. Everyone is driven by a motorcontroller... how diff. can it be ?
The Roover had a floppy drive (1.44Mb) and some serial ports.
The floppy are not FAT format....
Old 02-17-2009, 08:30 PM
Hi Mario B,
you did not mention your controller type but i guess it is the CNI RT480, this control is already obselete and a few technician in Biesse knows this, but i do remember that CNI used to have a CAD CAM software for this type of controller. Biesse already have a new software called Biesseworks but unfortunately it is not backward compatible. your best bet is to ask your dealer or Biesse directly for the old CAM software if it is still available (I think it is still available as CNI is part of Biesse). if you still require info, PM me.
Regards,
knap
Old 02-18-2009, 02:55 AM
Hi, knap.
Tnkx for the reply.
I'm getting the feeling, my dream won't come true.
Is there a software where I can draw a 3D part on a PC and get the G-code in a .txt file automaticly. (I don't even know if my Biesse works in G-Code)
How the code will get into the CNC is step 2.
tnkx
Mario
Old 02-18-2009, 09:08 PM
Hi Mario,
In the market the most accessible is AlphaCAM, and if you can find the old Biesse post then output of this you could directly key in to the machine controller. as for your info Biesse uses G codes but they also use fixed cycles (sub-routines) built by Biesse so instead of creating long lines to initiate a sequence it would instead be created in a single line, usually on the end of the line you would see L=???? (where ???? is the name of the fixed cycle)
cheers,
knap
Old 02-19-2009, 02:39 AM
Hi Knap,
Thanks for your time.
I have contacted planitsolutions in the UK.
Let you know what there answer will be.
thanks again.
gr Mario
Old 02-22-2009, 02:00 PM
battwell is on a distinguished road
click my name and read my other posts. things are possible... but not much!
Old 02-23-2009, 12:44 AM
Hi, all...
As I said, I've contacted Alphacam and they are comming today to my workshop. They are convinced to have a solution for me.
Let you now...
gr
Mario
Old 02-23-2009, 04:08 AM
makes sure they show you it do something on your machine!
make sure they can output the code to disk in cni format! ( i have software for that)
is your running program limit 11k like most biesse old machines? if so useless for anything more than the simplest of jobs!
do you have the serial port connected on your machine?
alphacam is fantastic software, if your machine can run the code it generates- (your machine is probably limited to approx 350-400 lines of code max to run as 1 program)
id be interested to know what they say.
by the way alphacam works great for 2d panel work on biesse
  #11   Ban this user!
Old 02-23-2009, 05:52 AM
Hi there,
Alphacam has just left the building...
My first impression ? hmmm.... I have the impression they do not know Biesse.
I had to show them how we build a program now, what kind of codes we use... I suppose that every Biesse works in the same language (?)
This would not be the question if they already had solved this kind of problem... but I can be wrong of course...
They will search now for a solution on how to transfer the data from my PC to the CNC. It will be with a floppy disk...
I think we'll talk 20.000€....
  #12   Ban this user!
Old 02-23-2009, 01:24 PM
20000. wow!
what controller do you have on your machine?
i have software to write floppy for cni on windows based pc
you can use bobcad for about £300! i have postprocessors ive written for biesse
if your considering 20000 id put your money into a controller refit instead.
what do you want to make, product?
Biesse rover 36 postprocessor Ninjabiker CNC Machining Centers 25 12-11-2010 02:03 AM
Biesse Rover 20 NC410 Jamf2 Commercial CNC Wood Routers 22 10-12-2010 06:55 PM
microvellum for a biesse rover 4.4 robbie prime CNC Machining Centers 2 07-07-2009 12:19 AM
Biesse Rover 22 paul sharpe Teachers Hang out 2 10-09-2007 01:50 PM
Biesse rover 20 Fault satori Commercial CNC Wood Routers 5 09-27-2007 09:37 AM
