Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 01-28-2008, 08:38 PM
razza62 is on a distinguished road
Routing bits to cut thru MDF
Just wondering what you should use to cut straight through an MDF board... What i'm intending on doing is cutting through a 9mm board, then using a bevel bit at around 45 degrees to get the finishing edge. I'm cutting through the board so i can have inlay mirrors in a wardrobe door. Do i use a straight through bit, or can somebody point me in the right direction where i could purchase the bit i need?
Old 01-28-2008, 08:58 PM
ger21's Avatar
If your going to bevel the top edge after, just use an upcut spiral bit. For fastest cutting, use a chipbreaker upcut spiral. Chipbreakers are much quieter too. Keep in mind that the top edge may be a bit fuzzy, but it won't matter if you'll be beveling it after. These are the bits that I use.
http://www.vortextool.com/standard/p...fm?groupID=266
If you need both top and bottom edges clean and sharp, then use compression spirals like these. http://www.vortextool.com/standard/p...fm?groupID=272
Old 01-28-2008, 10:31 PM
Cheers, i just ordered a 3 flute compression spiral bit and a 90 degree chamfer. thanks for that
Ramon
Old 02-08-2008, 06:24 PM
vcarver is on a distinguished road
Great Site
Hey I just joined here but I know a great place for bit is www.routerbits.com
Help Routing MDF? lgroulx200 DIY-CNC Router Table Machines 7 09-17-2008 08:09 PM
Source for tool bits for pcb isolation routing guru_florida CNC Tooling 1 01-24-2008 10:01 PM
New to CNC Routing need some help .... Beardown DIY-CNC Router Table Machines 8 05-05-2007 10:37 AM
Q on CNC PCB Routing soundmotor DIY-CNC Router Table Machines 7 04-27-2006 07:16 AM
What type bits for routing PCBs? cp8071 DIY-CNC Router Table Machines 4 02-22-2005 11:08 AM
