Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 01-14-2008, 08:04 AM
crodrigues is on a distinguished road
TPA - PTP400 Is there anyone who knows this CNC?
I came across this controller and I dont have any manual. I found by looking at other ISO programs that I can use L, H and S in the code to designate Lenght, Height and Thickness. But, what I would like to know is if there are other variables to use.
CNC90, another TPA more recent controller allows us to use A-I letters as variables. I wonder if PTP400 has it too.
I have a parametric program I need to write and any help is apriciated.
Carlos
Old 01-20-2008, 10:55 PM
mechona is on a distinguished road
The website for the controller manufacturer is http://www.tpaspa.it/tpa/ENG/index.html. Give them a call they might help you.
Old 01-21-2008, 05:09 AM
Hi mechona,
I already did this once regarding CNC90 controller on Vitoria Albertti italian machine. Never got a reply.
Anyway, I'll try again. Thanks.
Carlos
Old 10-02-2008, 02:31 PM
hagfors is on a distinguished road
Originally Posted by crodrigues View Post
Carlos
Are you still interessted in ptp 400, I have a version from 1988..
Old 11-15-2008, 09:31 PM
electricEd is on a distinguished road
PTP 200n
I trying to repair a friends Alberti Vittorio 'Uno' NC Borer. It uses a TPA, PTP200n controle board. The Y axis moves but does not count and therefor will not stop before it hits the emergincy stops at the end of its travel. I'v been looking for a schematic or some technical advice with no success. I've tried contacting TPA, but did not get a response. I would appreciate any advice.
Old 11-16-2008, 05:17 PM
seams to me that it is the encoder of the y-axis motor that have broken, or connections to it. (if the encoder is totaly disconnected it will run the axis at full speed until it stops by the emergency switch..) I bought an encoder from V.alberti this summer, turned out it wasent the problem. the encoder counted but didnīt stop where it should and therefor showed an error message. turnd out it was the servocard for the motor(located in the computerbox) that haved broken beacuse it was a fault in the motor itself.
Cost for an encoder should be about 200$ I think..
email for V.alberti: service@valberti.com,
or mail directly to:
Patrizia Confalonieri: ricambi@valberti.com
(she was my contact when I bought spareparts.)
Good Luck / Micke
Old 11-16-2008, 08:13 PM
encoder?
Good Luck / Micke
Originaly I thought the same thing. I pulled the encoder and resoldered all the conections, even replaced the caps. I can see the indicator LEDs on the back of the encoder blinking when the motor is turning, also the display on the TPA flashes between 1-0 when the motor turns. This tells me the encoder is sending signal to the controle. Right? The fact that it is not counting the 1's and 0's or is being constantly reset, is the direction I am leaning. I swaped the 2 "direction desriminator" chips with no change. one is definiately for the X axis and the other for the Y axis. I've tested all the diodes and opto-couplers. The X axis works fine ruling out the crystal and microprocessor. I'm not sure where else to look without a schematic. I greatly appreciate your insight, and your experience. I sent another email to TPA, and now I'll try to contact V. Alberti thanks to you. Thanks again for everything. Please let me know if you think of anything else.
Ed
Old 03-16-2009, 08:41 PM
Dumitru Nechifo is on a distinguished road
PTP400
I work with some one of this ''Junior 7'' CNC. Are you still interested ?
Old 04-06-2009, 01:30 PM
router_router is on a distinguished road
Convert ISO File to valberty machine
How can help me
I will put a ISO NC Programm to valberty machine !
How is the best or rightest way to do this ? On Floppy i have fileformat that i cant read and some one that i can read ! Need i a translater from Iso to Valberty specially format ?
Thanks for help
Router
