Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 10-24-2007, 06:57 PM
Moderator
bp092 is on a distinguished road
horizontal cnc boring machine?
This is kind a shot in the dark, but I've been looking to find a commercial horizontal cnc boring machine. It would be 3 axis, rather simple with some kind of square fence and would mill out plate/butt hinges on doors. I've seen several companies advertising the use of aggregate heads on their spindles but that is more for line work and what I need is for use on custom work. More or less lining it up with a center point and running the program with the specified dims already factored in. Not sure if anyone has seen a machine like this before or seen someone here try to build anything like it. Any info would be appreciated.
Old 10-24-2007, 10:51 PM
toastydeath is on a distinguished road
Are you talking about like, a standard horizontal boring mill or horizontal jig borer? Or is this substantially different than commercially available horizontal boring mills?
Machinist - Horizontal / Vertical boring mill operators quinnj Employment Opportunity 0 10-18-2007 12:26 PM
Horizontal and Vertical boring mill operators quinnj Employment Opportunity 0 10-16-2007 02:58 PM
Horizontal Boring harryn K2CNC 9 06-30-2007 12:37 AM
OKK CNC Horizontal Milling Machine HMA460P bum1033 General CNC (Mill and Lathe) Control Software (NC) 0 12-01-2006 11:03 PM
New Photos! Horizontal Boring Mill (30HP) mzartop6 CamSoft Products 1 09-11-2006 09:11 PM
