| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
I already posted a question about this but I think it went to the wrong area. Appologies for the repeat. I am starting to use a precix 8400,(4X8). I have precious little info in terms of owner's manuals etcetera. What I don't understand is the vaccuum table principles. Can somepne explain it to me. What should I use as a sacrificial substrate? (mdf?) What thickness? Should I bore 1/16th inch holes everywhere? Should My vaccuum moters get so hot? Should I connect the vaccuum table outlets to my dust collector? Should it pull vaccuum through a piece of 3/4 mdf? any opinions would be appreciated. Joe |
| Well Joe you must be new to CNC. Vacuum table is very useful and simple. My machine has a 15HP regen. blower that pulls 14" at 330CFM. This will suck through 3/4" light weight MDF with no problem. My table is setup with 4 zones. That vacuum chamber is 2 sheets of 3/4" plywood glued together. I cut the 4 zones, with a hole in the middle, with a round nose bit. I cut a dado for a 1/2" wide 1/8" thick gasket around the table and between the zones. The vacuum chamber was sealed all around and bottom. I surfaced both sides of the MDF. Throw it on the vacuum chamber and you are ready to go. I use a vacuum gauge and monitor the pressure. |
| My cnc table | scrambled | Plasma, EDM and other similar machine Project Log | 104 | 07-24-2010 09:11 AM |
| My DIY table | CNCadmin | DIY-CNC Router Table Machines | 13 | 05-13-2008 09:28 AM |
| precix vaccuum table | joemc | General Metalwork Discussion | 0 | 10-18-2007 08:47 AM |
| XY table design basics, linear ways to table size ratio? | Konstantin | Mechanical Calculations/Engineering Design | 0 | 03-13-2007 01:21 PM |
| CNC using xy table | tats | General Metal Working Machines | 2 | 11-25-2004 10:30 AM |
