| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| guys I'm trying to convert an old techno isel router with mac 200 controller to gecko drives and run it off Mach 3 I have rewired the controller but I can't get any readings off of the limit switches . Does anyone know what kind of limit switch set up techno isel uses, is it optic sensor or magnetic ????? Any help will be greatly appreaciated. Thanks in advance. Chuck
__________________ Jack&Master |
Well I figured it out after a long day of discoveries. First the good news, apparently the machine had just had all the ball screws replaced. But in the process the installers destroyed 1 limit switch, lost a plunger attachment to the Y axis , stole the plunger from the Z axis and placed it on the Y. The Z axis plunger was too short for the Y axis so it never hit the switch, and of course without the Z axis plunger the high limit on the Z axis was useless. So after fabbing a new plunger for Y and moving the original plunger back to Z and getting a new micro switch from Radio Shack I finally have all the Home and limits back together. Now the big question in the instructions for my Cnc4pc C-10 breakout board it shows the the home and limit switches as normally open, that would mean that you would have to parallel all 6 switches together, would'nt it be better to run the 6 in series loop??? Or is this 6 of one half dozen of the other???? Chuck
| I too use the CNC4pc breakout boards but I modified them to work with Mach3. The cnc4pc needs a low pass fiter installed on the limit switch lines. The switches in the Techno are all wired normally closed. Thus I cut the trace from each switch terminal on the CNC4pc board. Installed a 470 ohm resistor between the +5 terminal and the switch line. I used pin 10 for X, 12 for Y and 13 for Z then I removed the 10K pulldown resistor and install the low pass filter by soldering them directly onto the IC pins. If you need more help contact me at dmauch@camtronics-cnc.com On the 6 Techno retrofit that I have done I think that the existing control units were subject to stepper motor resonance problem in circular moves because are simple bipolar drivers with no mid band stabilization and aren't microstepper.
| I have done 6 techno retrofits on both the stepper and the servo systems. I can build you a custom 3 axis unit that runs off mach3. It retains your existing motors and cables if you have the stepper system. Contact me at dmauch@camtronics-cnc.com |
| Used Techno-Isel $40K Opinion, others to consider? | 68rustang | Commercial CNC Wood Routers | 11 | 12-28-2009 12:00 PM |
| Techno-Isel Components | CAMCRASH | Linear and Rotary Motion | 1 | 05-12-2008 12:26 PM |
| Techno Isel | wood_donkey | Commercial CNC Wood Routers | 2 | 04-19-2007 07:13 PM |
| Techno -isel windows 98 | Dan Orlandi | CNCzone Club House | 0 | 01-11-2007 12:19 PM |
| Techno Isel Blues | Les the Luthier | Commercial CNC Wood Routers | 6 | 11-27-2006 08:18 PM |
