Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 10-09-2007, 11:16 AM
68rustang is on a distinguished road
Used Techno-Isel $40K Opinion, others to consider?
I have a manufacturing shop that works primarily with Polypropylene plastic. I am looking to purchase a 5' x 10' or 4' x 8' router to cut some of our parts with. I have found a used Techno-Isel that the current owner wants $40K for. I don't know the exact model but I believe it is similar to the current LC"X" series. What I do know about the machine:
  • It is 4 years old and looks to be in fairly good condition, I have seen it is person.
  • The work envelope is ~60" x ~96" x ~11" bridge clearance.
  • It is equipped with a vacuum table, but no pump.
  • It is equipped with a 6 station pneumatic tool changer
  • It is equipped with a 15" touch screen display
My intended use is cutting plastic pieces that range in thickness form 1/4" to 3".
I know it is a vague question but is $40K "in the ballpark" for this machine outfitted the way it is?
Are there any brands out there comparable to Techno? Everything I have found is either DIY or like the Techno Premium class which is overkill for what we do.
-Eric
Alibre Design Expert , SheetCAM, Tormach PCNC-1100, Techno-Isel RG-5996.
Old 10-09-2007, 01:34 PM
SCRAPWOTSCRAP is on a distinguished road
For your referencing pleasure.
http://www.cncrouterstore.com/
Old 10-09-2007, 01:43 PM
Thank you for the link. Looking through there the price looks to be "competitive."
-Eric
Old 10-09-2007, 04:33 PM
Kent_Norway is on a distinguished road
I was considering a TECHNO my self, but in my area
they charge so much for it (new) that I simply stopped considering machines
from them directly. I have looked at the www.cnc-step.com and www.bzt-cnc.com
which I have posted below on, but there seems to be nobody which has any type
of experience, or bother to discuss them, with any of these. HighZ has dealers in the US
and are at least much more "payable" for me. If I had my hands on you´re deal and everything
looked good, I would for sure gone for it. But I would have checked it thoroughly :-)
K
Old 10-10-2007, 09:25 AM
RandK is on a distinguished road
Machinery Masters has had a listing for a demo Techno RG machine for a while but have never filled in the details on it. It might give you another datapoint. You didn't mention the HP rating on the spindle that's important to the price. $40k sounds a bit high to me if it is an LC class machine. Suggest you get Techno to quote a similarly equipped new machine and find out what their support policy is for buying a preowned.
Old 10-10-2007, 09:49 AM
Thank you for the replies. I was mistaken it is not an LC"X", it is approximately equivalent to a current RG-5996. I say approximately equivalent because the major assemblies are the same but I see small differences in the catalog. I can attribute that to it being ~4years old. I have contacted Machiniery Masters.
-Eric
Old 10-11-2007, 09:31 PM
partsman is on a distinguished road
That may be a good price but if it is more machine than you need it might not be a good deal. Have you taken a look at a new LC series. I just ordered a 4x8 LC with no ATC & no vac (plan to make my own). I got the High speed servos (800ipm) & 5hp spindle for under $26 (including a $2000 delivery fee ). Just something to think about.
FWIW: I also have a PCNC-1100
Old 10-12-2007, 08:47 AM
I appreciate the input. The RG with ATC and vac table are exactly what we need. The LC is too light with the extruded bridge without a reinforcement beam.
The PCNC is a nice little machine. I haven't done any true 3D yet because I have been having software issues. Nothing directly with the PCNC but the CAM software I have been using has been giving me trouble.
-Eric
Old 12-27-2009, 06:06 AM
Plastix is on a distinguished road
Smile Techno - Plastics
Hi 68Rustang
We are UK based plastic machinists (nylon, UHMWPE and delrin up to 2" thick).Have you bought a Techno router and are you happy with the machine? Are you sure that an Techno LC could not do the job?
Doug
Old 12-27-2009, 09:17 AM
Yes, I ended up buy the used Techno I originally posted about. I went back to the seller and ended up getting it for significantly less than he was originally asking. It is an RG-5996. Techno has been very good about supporting it even though I bought it used and I have been happy with the machine in general. It sounds like your uses will be similar to ours. My machine has some flex in the bridge even with the steel tube reinforcement. Not an unmanageable amount but it has to be taken into account when programming speeds and feeds.
I don't like the Techno software. If I had the time I would look into converting it to run Mach3. I wish the factory would support it but from my conversations with them they don't plan to anytime soon.
-Eric
  #11   Ban this user!
Old 12-27-2009, 12:31 PM
Hi Eric
Thanks for the prompt reply. Do you machine mainly Polypropylene sheets? What thickness do you machine and what sort of tolerances are you able to achieve?
Regards
Doug
  #12   Ban this user!
Old 12-28-2009, 12:00 PM
Mainly polypro and acrylic sheets. The thickest to date has been 2". I can hold <.010" without even trying. That is more than most of what I am cutting requires. I have cut some large 4p plastic gears that Were within .003". I use mostly Onsrud Super "O" cutters and they work pretty well. I have been fighting cutter flex and chip issues with the extended cutters though.
When I first set the machine up it was cutting egg shaped circles. A quick realigning of the bridge fixed it.
-Eric
Techno-Isel Components CAMCRASH Linear and Rotary Motion 1 05-12-2008 12:26 PM
Techno Isel wood_donkey Commercial CNC Wood Routers 2 04-19-2007 07:13 PM
Techno -isel windows 98 Dan Orlandi CNCzone Club House 0 01-11-2007 12:19 PM
Techno Isel Blues Les the Luthier Commercial CNC Wood Routers 6 11-27-2006 08:18 PM
Techno-ISEL MAC 100 software? wmb General Metalwork Discussion 0 08-09-2006 04:39 AM
