Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 09-25-2007, 02:36 PM
kentauto is on a distinguished road
Digital Tool
I'm looking for contact info for Digital Tool
I have a custom built DPK72004XDTI Anaheim Automation Drive
giving me a fault and I need the manual....Anaheim say's they
do not have one, So I'm looking for information on the above
drive before I spend a couple hours driving to the machine for the
first time.
I've been told the fault light turns on.....That's all I have
at the moment
Jason Wilson
Old 09-25-2007, 03:19 PM
turmite is on a distinguished road
Jason what year was your machine made in? There were several different versions of the Digital Tool using different Anaheim drive pacs. It would help to know about when the machine was made.
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 09-26-2007, 09:36 AM
Can not find the date, but it use's wincc with 6 Axis Card
Old 09-26-2007, 09:38 AM
Does the machine use rack and pinion on all axis?
Old 09-26-2007, 03:03 PM
The Machine has Rack On the Y & X
And a Screw on the Z and W (Which is the 2nd Z Axis)
Looking at the Power Pack I'm getting 30 Volts, and the Cards want a nominal
60 VDC.... the Motor is Specced at 160VDC on it's sheet....
And I'm seeing some cablling problems....
Right now I'm looking for alternative systems... I have the controllers we use on machinery everyday but it would be a $10K Retrofit for All of the Electronics.... It'd beat the open loop and I could gaurantee uptime.....
As of Now I'm looking at either putting in our tried and true system or re-designing the current one....
Old 09-26-2007, 05:38 PM
Ken my machine is much earlier than your's and the drive pack is different. Sorry.
BTW my machine is retrofitted using Mach3 and Geckos while still using the power supply part of my drive pack. I promise you it is not $10k but then again, it isn't closed loop either. One more thing you need to be aware of on these machines are the little .375" shafts that are attached to the stepper motors via a coupler on the x and y. On my machine, they used a 1/8" pin to hold the first gear on and both of them broke.
Mike
Old 12-17-2008, 02:27 PM
thescenicroute is on a distinguished road
Digital Tool
CNT Motion in Pittsburgh is run by the guy who started digital tool. Give them a call, they might be able to help.
Old 02-02-2009, 02:16 PM
Matt McColley is on a distinguished road
not 100% sure, but I think the DPK series is the same as the DPF series, but with an 800W power supply instead of a 600 W one.
here's the DPW manual http://www.anaheimautomation.com/man...rs%20Guide.PDF
We run a DT Tool Meta Machine.... they closed up shop and re-morpehd as Digital Tool, and then again as CNT Motion. I'm quite sure it's the same guys.... all out of Pittsburgh
Old 02-03-2009, 03:27 AM
cabnet636 is on a distinguished road
bill glenn at camaster knew a lot about those routers he still has one he cuts parts on, when i purchased a 10 year old machine of his it had an anehiem controller on it, i have since retrofitted it with wincnc, new drivers and motors.
he is at
www.camaster.com
phone number is on webpage
jim
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
Digital tool dr902 wiring diagram brockadeau BobCad-Cam 1 05-16-2007 12:41 AM
US Digital MD1 Controller Mooser Stepper Motors and Drives 2 01-21-2007 05:51 PM
What is considered Digital or not? JerryFlyGuy General CNC (Mill and Lathe) Control Software (NC) 13 11-24-2006 07:32 PM
My digital creation ( Nothing to do with CNC) ynneb CNCzone Club House 9 02-08-2006 10:57 PM
Digital Tool Meta Machine Stratoscat Ability Systems - LPT Indexer and G-Code 1 09-29-2004 10:01 AM
