Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 08-14-2007, 01:35 AM
mcmxl22 is on a distinguished road
Question Busellato Problems
I work for a cabinet making company that has three Busellato CNC machines. One of them keeps coming up with an axis error (x axis not OK) and (movement not ended). This happens in the middle of a program and makes it so the program has to be restarted. I discovered that running the machine through a warm up program will "cure" the problem for a couple hours. People think this problem is caused by some electronic equipment getting to hot. I disagree because if this were true it should happen during warm up...but it never does. Any ideas? It is a Busellato Jet 6000XL.
P.S. I am new here and this seemed like the best place to post this question.
Old 09-23-2007, 11:58 AM
karbunkle1952's Avatar
karbunkle1952 is on a distinguished road
We own a Busellato Optima and are getting a X axis servo error.
The Braking resistor indicator led would come on the servo drive, it's the LED on the very bottom of our unit.
We replaced the resistor and am hoping it cures the problem we are having.
Our machine would stop in the middle of the warm up program.
Old 11-09-2007, 09:11 PM
Servo was the problem
We had our Busellato Maxi Drive rebuilt and that took care of the stopping in mid warm up.
Seems we had arcing on the DC side of the circuit board in the drive.
Old 05-21-2009, 11:59 AM
barhoum is on a distinguished road
hello
please i have a busellato and i have the warning message
263: icnc temps épuisé en tentative de la réponse dans la connexion TCJ2
tcj2 is a thermocouple that is related by COM1 port
thank you
Old 09-03-2009, 09:20 AM
menuisier is on a distinguished road
hello there I see what you mean, the problem here is the data cable cat5 or 6 is broken, in some place p/s check your cable management and change it cheers regards menuisier
Busellato vs Weeke MARKC53 Commercial CNC Wood Routers 11 11-22-2011 05:33 PM
Arc problems nda22 Mach Lathe 2 07-03-2007 07:19 AM
Point to Point Busellato Malacara CNC Machining Centers 3 05-01-2007 05:41 PM
Tap Problems Skeeterd5150 General Metal Working Machines 33 06-07-2006 03:12 PM
Run from here problems? CNCadmin Mach Mill 5 11-30-2005 09:38 PM
