| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
We are a sign shop that is running 4 multicams. We are having issues with our 3000 series. Its throwing error messages -main one being servo error and the xa drive will be flashing. We think it is static related as the error will happen 5 times in a day and then not for a couple of days. Anyone had this fault, and how did you get rid of it. Multicam will not get back to us Thx |
| Hi I operate a Multicam 3000 Router.I had a problem where it also told me it had a servo fault which turned out to be a mechanical fault on the Z axis.Next time it happens count how many short flashes the led does, each different codes means a different fault.I have a friend who works at the South Africa Multicam Dealership, will ask his advice.I had the papers with the different code faults but lost it somehow.I have never experienced a static problem only now and again I experience power glitches due to dips in our electricity supply. Edmond |
| we have been getting 3 flashes- which indicates too high voltage (?) We have adjusted this as per spec and it does nothing to stop the error. We have changed the z drive motor as we had the same issue previously but this time it will not go away. |
| Xa servo drive fault could be anything from a bad servo to a broken wire in the encoder bundle. Our previous X axis faults on our machine related to a drive that had gone haywire from time to time and then finally up and quit. Our last X axis servo fault was the servo itself with a bad internal encoder glass. Sent it out to a servo shop to get repaired and we are back up and running. We did re-check all the drives at the time and everything is OK with all components. Have you talked to your dealer support people?? Good Luck, Tom in PA |
| We tried the drive swap and it didnt do anything. We seem to have minor success with most things we try, but then the prob comes back after a day or two.We used static guard and it worked fine for a week, switched over some cables fine for two days... I think that there must be some crimp in the cabling, but we cannot find it. I guess we are heading to a complete cable replacement. At least Multicam Canada are talking to us now after we got Texas involved! |
| new to hobby, answers appreciated | vietrat | Mastercam | 6 | 10-03-2007 11:30 PM |
| Advice greatly appreciated for a Noob. | Kammo1 | DIY-CNC Router Table Machines | 16 | 06-05-2007 03:13 PM |
| Starting knee-mill retrofit. Your input appreciated. | jamma | General Metal Working Machines | 2 | 03-01-2007 10:41 AM |
| CMOS errors - (again) | Healey | Bridgeport and Hardinge Mills | 4 | 10-29-2006 09:08 AM |
| any info is appreciated | bthomps5 | Mastercam | 4 | 04-11-2006 10:17 PM |
