Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 05-15-2007, 10:23 AM
SheldonB is on a distinguished road
Thermwood Router Table Repair
Looking for suggestions on what type of tools to use for drill & milling the hard organic composite table on our router (press oats or??).
Has anyone had any success in drill or milling these types of tables?
Do you use HSS, cobalt or carbide drills or mills?
Any special flute design? High helix?
Can you use some sort of lubricant "WD-40" without damaging/weaking the table material.
Any & all info is appreciated.
Old 05-19-2007, 08:29 AM
Mussel Kar is on a distinguished road
Are you talking about thick phenolic? If so then carbide is the best answer. You are looking for a heavy chipload and a low rpm to get better tool life(compared to wood). Low helix finishers work best for the final cut, if needed.
Old 05-19-2007, 08:40 AM
Use good masks while doing this, phenolic dust can be very irritating.
Old 07-18-2007, 04:14 AM
jaushaug is on a distinguished road
I've machined 60 or 70 black phenolic tables on routers. I faced with a 2-1/2" 45deg 5-insert indexable shell mill - 0.020" rough & 0.005" finish depth, 12000 RPM @ 400-500 IPM. Grooved with brazed carbide bull-nose spade-type endmill - @.150 deep, 12000 RPM @ 200-300 IPM. HSS drills work well at heavy chip loads and higher RPM than used in alum - ex. 1/2 drill @ 4000 RPM & 25 IPM with .200 peck. This was with 11HP spindle. With 5HP all the same except 1-1/2" shellmill because of shank dia limitation and drill slower (and only up to @3/8). Definitely wear a mask, I get sinus infection every time I don't.
Used thermwood parts zachf CNC Machining Centers 4 09-27-2011 07:27 AM
Thermwood cnc? tim in pa Commercial CNC Wood Routers 5 06-14-2011 12:56 PM
My New Thermwood Taz WoodWorking 2 03-31-2006 05:58 PM
Your first CNC Router Table widgitmaster DIY-CNC Router Table Machines 9 12-08-2005 12:40 AM
Post for Thermwood MegaMoog General CAM Discussion 0 01-20-2005 02:03 PM
