Results 1 to 2 of 2
Thread: hardeware pause pause detected?????
    May 2007
    looking for help with a hardware pause problem we just got a used conquest 1224 router it has a problem it boots up with "hardware pause" and sometimes in the middle of run it just come up with an error "hardware pause" no pattern to it.
    the pendant is acting up but i dont think the 2 problems are connected. the screen on the pendant will not display some times. Any ideas thanks jim
    May 2007
    I found it a wire had broke off inside the conduit on the backside of the gantry on one of the e stops. thnaks Jim C
  1. Pause under G-Code control
    By gregger2k in forum Carken Products (Deskam, DeskCNC etc)
    Last Post: 10-31-2012, 02:54 PM
  2. how to programmatically pause
    By Antonio_Emilio in forum LinuxCNC (formerly EMC2)
    Last Post: 01-27-2007, 12:32 PM
  3. How to pause Turbocnc
    By jimglass in forum TurboCNC
    Last Post: 03-27-2006, 06:06 PM
  4. VF-4 Tool changer pause!!
    By ZR Machine in forum Haas Mills
    Last Post: 11-01-2005, 07:52 PM
  5. Gcode pause command?
    By mark296 in forum G-Code Programing
    Last Post: 08-13-2005, 09:13 PM
