Results 1 to 4 of 4
Thread: What is the X & Y Location
    May 2006
    Exclamation What is the X & Y Location
    The question is: Does your CNC travel further on X or Y, and what brand are you using.
    Is there a standard?
    J
    Feb 2007
    New Zealand
    Talking
    Some poeple go with longest travel being X.
    Some people believe X is the one that is 'cross ways' when you're standing at the console/end/controller of the machine.
    Some say that Y is always the travelling axis on the gantry.
    Some say X is an unknown number.
    Some use a small crystal, hanging from a birch tree on a full moon night to determine the optimum placement and axis alignment for their machine...
    ie: toss a coin.
    May 2006
    Xy?
    I think your right. Seems all over the map. Do you have a CNC, what brand and where is the X?
    The general standard for the past few years, thanks to the sign industry, is the X is longer. I believe every vinyl plotters on the market, as well as large format printers work this way.
    Perhaps the older, big iron, CNC's would find it difficult to change their orentation. But for many of us sign guys it makes a difference.
    J.
    Feb 2007
    New Zealand
    Currently I only have a small home-built router... The X is the across the gantry tavel (Fixed gantry).
    I've worked with a techno router at a friends work, where the long axis was X. I found it a bit confusing, as you stood at the 'end' of the table where the console was, and it was difficult to think 'rotated' 90 degrees, and found using the remote pendant while standing 'beside' the machine easier, although not a good idea from a safety point of view.
    Cheers, Me.
  1. Zero location resetting mid-run
    By esmiller in forum Machines running Mach Software
    Last Post: 03-03-2006, 03:00 PM
  2. Location Pin Tolerancing
    By 123sxu in forum Mechanical Calculations/Engineering Design
    Last Post: 12-03-2005, 10:54 PM
  3. Map your location
    By Rekd in forum CNCzone Club House
    Last Post: 10-20-2005, 10:49 PM
  4. location
    By mocnc in forum DIY CNC Router Table Machines
    Last Post: 04-08-2005, 05:12 PM
  5. location?
    By fastolds in forum Surfcam
    Last Post: 12-02-2004, 02:58 AM
