| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
i own a shopbot cnc with a router i now want to upgrade to a spindle i know very little about spindles and how they operate i notice on ebay there is a couple of 7hp spindles. what i need to know if i was to purchase one of these spindles, what else would i need to go with the spindle , where can i find information on this? the biggest spindle that shopbot offer is a 5hp. would a 7hp be to big. thanks paul |
| You need a VFD to drive it, and it may require 3 phase power to run the drive. A 7HP spindle would most likely need 3 phase power. One other thing to consider when buying on Ebay, is that the cost to have a spindle rebuilt can easily exceed $2000-$3000
| Gerry is right about the VFD. That could cost $3000. And you will need 3 phase. But - I really think 7HP will be over kill and way too heavy for the Z to lift and Too heavy for your Y car. As for rebuilding, I bought a used 3HP package that the owner said was in good shape, tight bearings and was running good the last time he used it. Well after making a mount, wiring and figuring out how to program the VFD, 30min running and the bearings were shot. I got a quote of $2000 to rebuild. I did it myself for $30. I would look for something a little smaller than 7HP and find a package with the VFD. Then plan on replacing the bearings. And you will still need 3 phase power. |
| [QUOTE= 30min running and the bearings were shot. I got a quote of $2000 to rebuild. I did it myself for $30.[/QUOTE] Woundering how you got angular contact bearings for $30, if ones with a 30mm bore are around $600 a pair.
__________________ Dennis |
| Sweo spindle drive? new mill dead spindle | Shizzlemah | Fadal | 13 | 12-18-2008 11:11 AM |
| interact 4 spindle drive won't turn on spindle | 0041601 | Bridgeport and Hardinge Mills | 7 | 06-23-2008 05:51 PM |
| more rpms for spindle motor and spindle | bob1112 | Mechanical Calculations/Engineering Design | 33 | 02-10-2007 01:01 PM |
| spindle air | fadalman | Fadal | 2 | 12-09-2006 12:15 PM |
| Just had my spindle reground by Spindle Grinding Service! | Edster | Fadal | 30 | 06-16-2006 10:48 PM |
