Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 02-09-2007, 01:09 PM
bully is on a distinguished road
CNC Machine for shaping snowboards?
We run a small snowboard company that produces about 200 boards a year. The one thing that we still out-source is the cutting and shaping of the wooden cores to a CNC shop. We are looking into purchasing our own CNC machine as it will hopefully be cheaper and also allow us to do some more prototyping and tweaking of the design. We dont have a huge budget for a machine and would like to start small to try it out. I don't even know where to start, we would need a machine that can cut at least 35cm x 90cm. I've seen one that is really cheap, but maybe not so reliable...more of a hobby machine. The Carvewright, its small but can do any length as the wood moves not the router. Is there anything else like this but a little more heavy duty? Any advise would help.
Thanks,
Jeff
November Snowboards
Old 02-09-2007, 03:33 PM
A little more...
We would like something that works with autocad or similar programs. We also would like to spend under $5000....Would building one be worth the savings?
Old 02-09-2007, 03:39 PM
ger21's Avatar
Since you need almost 6ft of cutting length, you'll have a hard time finding something for $5K. Depending on your skills (and tools), you should be able to build one for about that.
Old 02-09-2007, 03:44 PM
My bad, I was wrong on the dimensions i need about 40cm x 90cm.
Old 02-09-2007, 04:40 PM
ger21's Avatar
http://www.k2cnc.com/Machines/CNC-ro...925_detail.asp
Old 03-10-2007, 11:37 AM
thinkntink is on a distinguished road
Canadian design looks promising
We use K2 CNC machines and are amazed by the price/performance. Nothing else out there even seems to come close. That being said, GorillaCNC in Canada (eh?) is sporting some pretty promising machines.
Ron Reed
Think & Tinker / PreciseBits
surfboard shaping router anthony-whalen CNC Wire Foam Cutter Machines 5 05-05-2010 11:43 AM
Mach 2 on old machine = great machine foamcutter Machines running Mach Software 6 12-16-2005 12:11 PM
Getting work(gcode) from machine a to machine b strat DIY-CNC Router Table Machines 9 07-07-2005 02:13 PM
"shaping" aluminum? smythe General Metalwork Discussion 20 08-06-2004 11:35 AM
