Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 01-06-2007, 11:52 AM
pfcary1 is on a distinguished road
need help with converting corel to g code
I am new at this and trying to make stencils with fonts and designs from Corel Graphics Suite X3. My machine has Mach3 loaded with Artsoft. I would like to know how, after I create an image or name in the Corel program, do I save it so it will convert over to g code when I import it
into Mach 3 for my router to carve the stencil. I have been trying to add
a .dxf tag and that doesn't seem to translate - the program seems to
want a .tap extension to work. I don't know the basic clicks to get to
the point from my text or picture in Corel to get the router spinning. Can someone please help me. Thanks for any advice. Peggy Cary
Old 01-06-2007, 12:31 PM
ger21's Avatar
You need to export it from Corel as a .dxf or hpgl file. Then, depending on what version of Mach3 you have, you either use the .dxf importer or LazyCAM, one or the other should be under the file menu in Mach3. You then convert the file into g-code, which you save as a .tap file.
Here's a Corel macro that may give you better results if you have problems http://www.candcnc.com/DXFToolDetails.htm
Old 01-06-2007, 05:54 PM
thanks / more help needed
Thanks - it worked and I am grateful. Perhaps you could
help me with the next issue - the conversion worked and
the g code shows up on the Mach 3 screen but for some reason
my router will now only hum a bit. It is as if I need to reset
something. It still works okay with some downloaded
programs (ie - Write German Bravo) that were loaded
with Artsoft - however, those fonts are very crude so
I really need to use the Corel. Is there something I need
to do to reset Mach3 so that the router will work after
converting Corel to g code? Thanks in advance. Peggy.
Old 01-07-2007, 07:09 AM
ger21's Avatar
Do you have a feedrate in your g-code? Sounds like it's set too fast.
