| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
Hello all, I am new to this forum and I hope I can contribute as much as it looks like I will get out of it. I have a Biesse Rover 4.4 and Biesseworks. We took over a lease and just got it setup, however, we did not opt for the training. I am a small closet company and was wondering if anyone new of a simple way to cut bulk parts using biesseworks until we can get cabinetvision installed? Thanks for all your help. ALS12 |
| You would need to draw the parts in Biesseworks, then you should be able to use BiesseNest to place them all on a sheet(s) to be cut out. I never did the training either, I basically figured out the software on my own. You can use the program to pretty much create any shape. My boss had me draw a partial elliptical curve for a large counter top template, so you can pretty much draw anything your imagination can come up with. |
| The simplest way is for you to accomplish this is to create several small programs in the native Biesse Works environment. Program 1 = 1 vertically bored hole with specified spindle at specified X & Y, Program 2 = line boring using optimized boring with multiple spindle drops, Program 3 = Simple routing program, one line, one arc ....contine doing this until all the features you use on the Rover are represented with one program ( saw, aggregates, program with tool changes, etc.) Then send all of them to Bobcam as text files explaining what each does. Hope this helps! Mark T. www.cnccustomservices.com |
| Sorry, the previous post was for rberkes. ALS12 - I have all of the training documentation for Biesse Works if you would like it. Please email me at ntek1@aol.com or visit www.cnccustomservices.com and email me so we can discuss method of delivery. Kindest Regards, MarkT. |
| still looking. How are you doing with it? |
I work on a Biesse Rover with Biesseworks. We use CabVision, Artcam and Biesseworks, each has its place. We just did a large cruise ship interior using mostly Autocad DXF files imported into Biesseworks. We imported the DXF files into Biesseworks using the manual import function, and then assigned router functions to the geometry on each DXF layer. The buttons to use are on the bottom of the Biesseworks screen. You can route, drill, pocket. You can also set the tool path to the left, right or center of the line, set tool depth, speed, feed rate, etc. Material is set up on the first box on the left side toolbar. After you finish toolpathing, click the magic wand tool to optimize, and then run a simulation. You can also send the optimized toolpath to your machine with a button on the left side. If you have difficultites with optimization its typically an error with a tool path or a problem with the DXF file geometry. Often if I was not able to mill a pocket due to geometry errors, I chose route instead, and used an offset to mill the pocket. Either that or I fixed the file in Autocad. When you import, if the imported geometry doesnt fit your material, you can either redraw the DXF file in ACad to have a 0.0 origin, or right click in the import side of the screen, and select move, center horizontal or vertical to get the geometry positioned on the material. When you import from Acad, you need to be sure to convert drawings to polylines. If you don't, Biesse will create a separate line segment out of each Acad line segment, causing the router to lift and replunge at each segment start instead of running a continuous tool path. Also, if areas to be pockets are not closed geometry, Biesseworks will give you an error message if you try to optimize a pocketing toolpath. Biesseworks has a great functionality in that you can turn on and off each individual milling operation by selecting/deselecting the tool path in the list on the left. For example if you need to drill holes on some units, but not others, you can simply click off the holes you don't want to drill. Similarly, its very easy to restart a file where you left off by simply unchecking the tool path for each item that has already been cut. Most programs, like Artcam, would require you to either edit the Gcode or rewrite the program to accomplish this. Its a good program, but has a big weakness in the CAD department- its NOT a CAD program really. But it does provide good control over the Biesse rover. Happy routing! WayneC |
| Hi all I too am impressed with the power available in Biesse Works. I am importing dxf files into Biesse Nest through the wizard, and am amazed at the way it can be driven through the layer names. I have figured out how to set all of the stuff like tool correction,leadins and outs, basicly anything on the first page of the machining properties. For the life of me, I cannot work out how to set anything on the additional data page. I would like to be able to set the number of horizontal and vertical (depth) passes to utilise onion skinning on small parts. A typical layer looks like this:TCHB1W0CD$MDF$TC1D1650DIR1IT8IA45OT8OA45 Can anyone help me? cheers |
#10
Hi sorry if i've posted in the wrong area but have Rover C6 and use BiesseWorks. Instead of using the program variables I have been experimenting with using the dim function in the VB script. i can also generate this code from excel when i do a window quote, however as there are many dim variables i need to paste many lines and BiesseWorks won't let me paste more than one line at a time, however it does let me copy and paste multiple lines that are already in the vb box. Any help would be much appreciated with this Example of Dim Function that i use: Dim WindowHeight WindowHeight=1200 Thanks heaps in advance |
#11
I have a 2006 version of the rover 2.3, i am experimenting with using bobcad to create gcodes and send them to the quote program. Has any one else been doing this type of work as i need to find out the best way to go about things. I have not been able to create a 3d file from within biesseworks, has anyone done this, if so please let us know how to achieve this. Jeremy |
