Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 12-28-2006, 01:45 PM
mg75 is on a distinguished road
Question PA Speaker cabinet building
Hello,
I currently use a table saw and hand-held router to build PA speaker cabinets. I was wondering which commercial CNC wood routers do you recommend for a DIY beginner working out of his garage. I will be cutting 4x4 sheets of 3/4 inch Baltic Birch plywood. I do extensive angle and miter cuts.
Budget = $4000
Thanks!
mg
Old 12-29-2006, 12:06 PM
Anyone please?
Old 12-29-2006, 02:47 PM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
You'll be lucky to find a 4x4 "commercial CNC wood router" for less than $4,000.00.
Let alone one that will cut your miter cuts, unless maybe you use a form tool (dovetail)?
And the cost of software.
What kind of shapes do you cut (any photos)?
Old 12-29-2006, 03:07 PM
Thanks for the reply...
please watch the video on this link (towards the end).
http://www.tcsaudio.com/
And these are the cabinets we are going to build...
http://www.frappr.com/fitzmaurice
thanks!
Old 12-29-2006, 03:25 PM
speakerplans.com/index.php?id=plans
and
tcsaudio.com (watch the video towards the end)
Old 12-29-2006, 03:37 PM
Switcher's Avatar
Moderator
OK, looks like ( www.speakerplans.com/index.php?id=plans ) you could do most joints (box), & maybe rough out the other parts that need a miter cut, then just do the finish miter cuts by hand (table saw)?
The hard part will be getting a 4x4 cnc, for less than $4,000.00, most I've seen are around $8,000.00
Old 12-29-2006, 03:53 PM
are there miter cut attachments available on the $8000.00 range routers?
Old 12-29-2006, 04:04 PM
Switcher's Avatar
Moderator
NO, just 3-axis.
Old 12-29-2006, 04:11 PM
Switcher's Avatar
Moderator
Is all of this your work? ( http://www.speakerplans.com/index.php?id=mywork1 )
If it is, WOW!!
Old 12-29-2006, 05:24 PM
ger21's Avatar
A 4x4 K2 is about 10K http://www.k2cnc.com/Machines/CNC-ro...050_detail.asp
A 4x4 shopbot is about $8K http://www.shopbottools.com/prtstandard.htm
You could cut 45 degree miters with a router bit, but the table saw would be much faster.
  #11   Ban this user!
Old 12-29-2006, 05:34 PM
If it is, WOW!!
That is not my work. Those setups in the pics are the work of the original cabinet designer, Rob.
  #12   Ban this user!
Old 12-29-2006, 05:39 PM
So, basically there is no machine that can cut all the parts for me instead of the table saw.
check this out and tell me what this person used...
billfitzmaurice.com/phpBB2/viewtopic.php?t=1501
thanks for all the help.
