Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 11-02-2006, 12:11 PM
la_coterie is on a distinguished road
Question What's the taper on this?
Not sure if this is the correct area for this, but I'm sure someone will say if not
I've a high frequency motor with this taper on the end, can anybody tell me the style of taper and where I might get a chuck for it? The large end's about 19mm - 3/4" I'm looking for a small collet chuck, ER16 or 20.
Name:	Motor taper.jpg‎
Old 11-02-2006, 06:05 PM
Gold Member
InspirationTool is on a distinguished road
It looks kind of like a JT33 drill taper, but you can't use those for milling or routing without a draw bar.
Old 11-02-2006, 10:20 PM
unterhaus is on a distinguished road
yeah, that's a lot of taper to use for milling. Probably a high speed drilling head.
Old 11-03-2006, 01:51 AM
I think that it's bigger than a JT33 taper and there's a thread in the shaft end, presumably for holding "whatever" on the end.
I'll check out the JT taper theory anyway & report back
Old 02-20-2010, 02:15 PM
petedd is on a distinguished road
