| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
has anyone ever used a cnc router to make the profiles of skis? is it possible to use a cnc router to cut the whole thickeness of a board even in multiple passes? using it like a saw? another question is if I make a large 4x8 cnc router will it not be very precise for small projects |
but in general will a large mill be less precise? I have a sherline that is very precise but if I wanted to do something that is about 1'x1' on the 4x8 mill would it work ok? thanks |
So If you start with high quality parts with tight tolerances, you will be able to manufacture more precise parts in the end. With precision comes cost. It's kinda like comparing a ballscrew, to a threaded rod (Hardware Store), it all depends just how tight a tolerance you need to hold. Are you building a cnc machine to build skis, only? If so, you could save money by keeping your cnc machine working area just a little bit larger than your largest ski. ![]() Jerry . |
