Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 08-22-2006, 11:52 PM
DAMike is on a distinguished road
CNC for MDF cabinets under 20k, 4-axis?
I知 looking for a CNC router in the 10-20k range. I知 going to be cutting 4x8 sheets of セ MDF, mostly cabinets. I値l be running about 25-50 sheets a month. The cabinets use cam and posts, so I壇 like a machine that can drill side holes, but none of them seem to be able to do that in my price range.
I have all my designs in AutoCAD, so easy conversion is important. I知 leaning towards a ShopBot, but I致e seen lots of good things about ShopSaber as well.
I don稚 mind getting an entry level machine and then adding some upgrades in the future, say for example upgrading to a spindle.
Any advice would be appreciated.
Thanks,
DAMike (newbie)
Old 08-26-2006, 06:47 AM
svon89 is on a distinguished road
Here is something that I have seen used very well, but only for sides upto 48".
The owner was using a shopbot router, and made the table so that the boards could be clamped with the edge facing up toward the gantry. Then the machine was set up to cut tennons, I am sure you could use the same principle to drill the side holes. Best of luck, if I could use graphics programs I could give a better representation.
Stephen
