Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 04-03-2006, 08:12 AM
sploo is on a distinguished road
US routers in the UK
I've just laid down some cash for a Porter Cable 892, which is on its way to me in the UK (we can't get fixed based routers over here).
I was planning to use a UK building site transformer (110Vac, 50Hz), and from the information I have it should be possible to wire everything correctly and safely.
However, Porter Cable tell me that I can't run the motor at 50Hz as it'll burn it out. Some electrically minded colleagues tell me that they think it'll probably be OK, and that PC are just 'covering their *rses'.
Anyone had any experience of using US tools in the UK, especially PC routers?
Old 04-08-2006, 09:54 PM
xlr8tr@mac.c is on a distinguished road
I've been using Porter Cables for years in the UK via the transformer you mention - no problems so far after hundreds of hours of use (touch wood)
Old 04-09-2006, 12:02 PM
Great news. Many thanks!
Old 04-09-2006, 01:11 PM
martinw is on a distinguished road
Dear sploo,
I found these people who deal with Porter Cable...
http://www.maxtool.co.uk/index/porter-cable/routers.asp
From looking at their website, I think that they imply that the 892 model is good for 60Hz only, whereas some of the other models are good for 25 to 60 Hz. Try giving them a ring.
Regards
Martin
Old 04-09-2006, 03:00 PM
sendkeys is on a distinguished road
For what i have seen, it will have less power and rpm . It may over heat so as long as you watch the heat should be ok.
If this is for production you could look into buying a 120/60 generator or maybe (you will have to look into it some more), a 110/50 then turning up the rpm.
Old 04-09-2006, 04:45 PM
Or get a VFD and just lock the output at 60 hz.
Old 04-11-2006, 11:48 AM
Martin - I found Maxtool a while ago, and asked them about use of the tool in the UK. No reply.
Plus the actual cost of getting hold of one via them was somewhat high.
sendkeys/Geof - I'm hoping that it should just work OK. It's destined for a CNC router (eventually). Can't say I've seen a 60Hz generator (and don't know anything about VFD's).
I suspect that anything fancy that can provide sufficient wattage would be pretty expensive.
Ah well, hopefully I'll get hold of it in the next couple of weeks and give it a go. I'll let people know the result!
Old 04-11-2006, 01:28 PM
Davidh is on a distinguished road
...a variable frequency drive would be a good way to go, It would be worth talking to someone who sells them and can spec what you need. Get one, play with it, use it and you have learnt a new trick
Do you know what the consumption (Amps or watts) of your new toy is?
Old 04-11-2006, 04:24 PM
I'm always interested in learning new stuff, but it does have to be cost effective. Could you give me an idea of how much these things cost?
It's rated as 2.25hp. I'd want something capable of delivering 2kW to be certain.
The building site transformer I've been looking at claims to deliver 3kW - for a pretty reasonable cost of 50GBP.
Old 04-11-2006, 04:59 PM
Yes, I know that cost effective feeling
You are looking at £200, unless you can 'aquire' one from somewhere.
  #11   Ban this user!
Old 04-11-2006, 05:28 PM
That's cheaper than I was expecting, but it's still more than twice the cost of the router.
If that was my only choice, then I guess it'd probably be better to get a powerful UK router, though obviously it'd have to be a plunge unit and I'd have to strip it down to use it as a spindle motor.
On that subject - why is it we can't get fixed base routers here in the UK? Idiot health and safety regs?
  #12   Ban this user!
Old 04-11-2006, 08:38 PM
JRoque is on a distinguished road
Hi. PC folks are probably also worried about the router's speed controller. While in theory it should work at 50Hz, they might know something about their particular setup that we don't. The speed controller is handy not only to set the speed but to maintain it while under load and prevent over driving the motor. While the VFD might be a good solution, those usually cost nearly as much as the router - sometimes more. If the motor overheats and you run out of options, remove or bypass the internal speed controller and use an external one; the type used with universal motors.
JR
