04-03-2006, 08:07 AM
Correlating material/spindle/bit to speed and depth | | Reading one of Gerry's posts, he gave some info ( http://www.cnczone.com/forums/showpo...9&postcount=11) that leads me to the following:
Material: Plywood
Tool...|.Radius.|.Depth per pass.|.Speed...|.Spindle
Spiral.|.?........|.19mm..............|10m/min.|.10HP
?.......|.?........|.19mm..............|.3m/min.|...2HP (too low)
Does anyone have further data correlating material, cutter and spindle horsepower to cutting depths and speeds?
What I'm after is a table that allows you to work out sensible depth per pass and cutting speeds for a given material/bit/spindle HP.
Also, the rpm of the cutter would be useful to know - I believe this is something to do with 'chip load'? |
