| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| Home limit switches I am still looking to buy a shop sabre but I am wondering about the price and importance of the home limit switches. They want $750 for the xy and z switches this seems rather expensive. Are home limits that important? What do they do besides tell you that you are at the left front and top of each axis? I can buy and install crash limits for a heck of alot cheaper. |
| Home and limit are different things. Home is an absolute reference for the machine and limits are just that. Some use the home switch as one of the axis limits but I do not think that's such a great idea - I guess it depends on the individual. That does seem a little steep for home and limit switches. But yes - they are needed. You can get by without them but this is not a good idea. Things go wrong and the limit switches can prevent damage to your spanking new machine. Scott
__________________ Consistency is a good thing....unless you're consistently an idiot. |
| To bad you couldn't buy the machine and have them knock off the cost of the overpriced control! Then set the machine up with Mach3! Why would anyone sell a cnc machine ($8 - $13,000) without limit switches (How generic can you get!) I couldn't find anything about limit switches on their site. Did they tell you they are not included ? If your buying the machine anyway, just buy it without the limit switches. Then add your own (Yes you have to have them!) On the "Shop Sabre" site, they claim you can add custom "M-Codes". So add a hardware switch, and a soft limit switch. The $750 is what we call price gouging! Thats about like the Bozos that try and charge close to a grand for a floppy drive! |
| Sounds like the correct idea, I'm an electrician so the hardware and wiring are a snap it's the connecting it in with the software that I will be stuggling with. For $750 it sounds like a worthwhile learning experience. |
| limit switches I have a shop sabre (without limit switches) and I am looking to install some; already ran the gantry off the table once. Can anyone help with the wiring? The paralel connector in the control box (that runs to the computer i/o board) only has about 6-7 wires connected (for the motors). My plan was to wire the rest of the pins to a bus block and connect limit switches, emg. stop, etc. to the bus. I am running wincnc. Is there anything I need know before doing this? Any help would be greatly appreciated. As an aside, I am very happy with my shop sabre, its well built and rugged, however support from shop sabre has been lacking. I have asked for schematics and instructions on upgrading the machine several times and haven't gotten a response from ss. Jon |
| limits Jon, Try wincnc.net they are very helpful and there tech named Troy knows the cdontroller inside and out. |
| For some real nice limit switches, check out the Microswitch line supplied by Honeywell. They are NOT cheap but they are nearly bullet proof. Deals can be scored on E-bay. THey hold up in wet, sloppy environment and just flat WORK. Yes, you can get micro switches and other cheaper ones from Digi-Key or Mouser but the Honeywell's are way, way more robust and worth the $$$'s all things condidered. I first discovered them on my Fanuc/Cadillac CNC lathes and they were factory installed in ~1979 when lathes were new. They're still functioning even though the wiring long since had to be redone. |
| Would limit switches be just as important on a machine running servos's? I realize the problems that can happen when running steppers, but with servo's there is a less likley chance of running off the edge and causing damage or am I wrong here..?? |
| More important with servos. If there is a problem with the encoders, servo will run at full speed with nothing to stop them. That's what limits are for.
#10
| Do they just cut the power to the servo's or are they connected to the softeware? |
#11
| That's up to the user.
#12
