Hi all
I have the use of a Wadkin CC2000S with Bosch CC100 controller. The machine hasn't run for 10 years, so I replaced the battery today.
I have tried inputting the Wadkin paramaters from a Bosch tape drive i found, but no luck.
Should the cable from the tape drive plug into the Bosch panel under the monitor or into the port behind the panel on the right side of the Wadkin?
Also, what port number and baud settings should I use?
Could I input the paramaters from a laptop instead?
Thanks for any help you can give
Dave
LinkBack URL
About LinkBacks
