Results 1 to 1 of 1
Thread: hot slaer cnc routers from G.Weike
    Feb 2012
    China
    WK2030 CNC router
    Adopt constant power water-cooled frequency spindle, high speed, low noise and long life.
    Three axises are precision ball screw vice transmission, reasonable structure, stable performance, good weight bearing ability.
    This machine is mini machine, low price, high performance, especially suitable for home and small enterprises,institutions to do processing .
    Users can assemble electric spindle and driving control system according to their own needs.
    Specification:
    X,Y axis working area:300 x 200mm
    Z axis working area: <60mm
    Table size: 370mm x 440mm
    Max. speed: 0 - 4,000mm/min
    Max. Working speed: 0 - 4,000mm/min
    Working delicacy: 0.015mm
    Reposition accuracy: 0.05mm
    Max. Feeding height: 60mm
    Command: G code *.u00 *.mmg *.plt *.nc
    Software: Type3、 Artcut、 Artcam 、Ncstudio
    Max. power consumption:1.2KW
    Spindle: 0.8KW variable speed, water cooled motor
    Spindle speed: 24,000rpm
    Work type: steppernd
    Working voltage: AC 220V, 50-60Hz
    Manner of receiving data: USB or PCI
    Running circumstance temperature: 0 - 45℃
    Relative humidity: 30% - 75%
    Weight: 57kg
    Attached Thumbnails Attached Thumbnails hot slaer cnc routers from G.Weike-wk2030_cnc_router.jpg   hot slaer cnc routers from G.Weike-spindle.jpg   hot slaer cnc routers from G.Weike-hander.jpg   hot slaer cnc routers from G.Weike-control_box.jpg
    hot slaer cnc routers from G.Weike-sample2.jpg   hot slaer cnc routers from G.Weike-sample.jpg
  1. G.Weike LC6090 - My experience
    By loopingfred in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 04-25-2012, 10:30 PM
  2. G. Weike DSP upgrade?
    By JohnnyChan in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 03-21-2012, 11:29 PM
  3. G.Weike Laser
    By Melody-gweike in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-28-2011, 04:20 AM
  4. Vision Engravers & Routers New Large Format CNC Routers
    By CNC602 in forum Product and Manufacturer Announcements
    Last Post: 09-22-2009, 05:56 PM
