Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 11-05-2005, 01:59 PM
SteveS's Avatar
SteveS is on a distinguished road
Need Controller Advise
I have a commercially sold Debece built router table DTR 200S that is giving me fits. I want to change the controller.
Current stepper motors are all Nanaotec, but different at each location.
All are 3.0 a.
Y is ST5818M3008-A at 2.1 v
X is ST5818L3008-A at 3.1 v
Z is ST4018M1206-A at 3.7 V
Software that I have is Mach II, BobCAD/CAM version20 and Rasterfratz. I want to buy VCarve Wizard.
Computer is running Windows XP home edition.
Machine has limit switches for all axis at zero.
Travel is 23” in X, 15” in Y and 3” in Z.
I would like to change the controller only at this time. Which controllers would support the motors, limit switches and software?
Also, what are thoughts on those motors? Are they directly replaceable with another kind? If replaced, would the original controller recommendation still hold?
I have not had this machine running enough to evaluate the full performance. Will be using it to create wood and plastic crafts and not precision metal tooling. Would prefer cutting speed over another decimal place of precision.
Steve.
Detroit Suburb
Old 11-05-2005, 02:20 PM
ger21's Avatar
It depends a little on your budget. Also, how many wires do the motors have?
For best performance, you'd want to go with Gecko drives.
To connect the limit switches, you'll need a breakout board. PMDX makes a nice one that the Gecko's mount right onto.
http://www.pmdx.com/PMDX-131/index.html
You can also get one from www.campbelldesigns.com, or www.cnc4pc.com
ger21's Avatar
What Detroit suburb, btw? I'm in Shelby Township.
Old 11-05-2005, 02:50 PM
SteveS's Avatar
Wires
Gerry,
There are six (6) wires coming out of the motors.
Budget is an annoyance, but not being able to use the machine is a bigger one. Also, want to do it once and use the machine for a while.
BTW - I am in Trenton, Downriver
Old 11-05-2005, 03:04 PM
SteveS's Avatar
Breakout and Controller
I looked at a couple of the sites mentioned. My novice impression was that the controller connected on one side to the stepper motors and the other side connected to the computer parralel port. The term breakout box seems to come up. Is there a place on the website for terms and examples?
Old 11-05-2005, 03:15 PM
*Registered*
HobbyCNC is on a distinguished road
Originally Posted by SteveS
Gerry,
How about HobbyCNC?
www.hobbycnc.com
Dave Rigotti
Old 11-05-2005, 03:49 PM
SteveS's Avatar
Hobby CNC "Kit"
Dave,
What is meant by "Kits requires PCB soldering skills?"
Have you built one?
Steve
Old 11-05-2005, 03:58 PM
ger21's Avatar
A lot of the more inexpensive drives usually are multiple axis, and have limit and home switch connections on the board as well, and plug directly into the parallel port. Most higher end drives, like Geckos, have terminals to connect the step and direction pins. A breakout board plugs into the parallel port, and has terminals for the step and direction outputs for the drives, as well as limit and home switch terminals, and sometimes relays. Some are also opto isolated to protect your computer from damage.
On a small machine like that, the HobbyCNC drives may work for you. For about $80, it might be worth a try. You have to solder th board together yourself, it comes as a kit.
Old 11-05-2005, 04:47 PM
phantomcow2 is on a distinguished road
Its safe to say Dave has built a Hobby CNC driver board. He owns the business.
By "require PCB soldering skills", that means that when you get the board it is not assembled. You get it in individual pieces, the pieces that when properly soldered make a functioning board. DOnt be dumb like me and try to solder it if you have little experience, find a friend or somebody who is experienced in electronics to help you! Dave might be able to for an extra fee. Still the price is tough to beat
But it sounds like the board would drive the motors fine.
