Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
  #85   Ban this user!
Old 07-20-2008, 04:00 PM
pike88 is on a distinguished road
cw250
I can send you a wire diagram. What is your email?
  #86   Ban this user!
Old 07-20-2008, 06:11 PM
nazca is on a distinguished road
CW250
victor@nazcageotech.com
  #87   Ban this user!
Old 03-07-2009, 07:20 AM
THE SIGN SHOP is on a distinguished road
chineeeeeeeeeeeeeeeeeeese stuff bought mine in (NFLD and so did a guy in NS Can.) from a Canadian dealer called www.intelicam.ca..................boy what a mistake 14 months later we are talking with a real time certified engineer in 45 min. we found out just how much the former ceo and his partner of cam tech knows about the product he now sells the machines never had a chance from leveling / screws / wireing/ programming
this guy even went so far as to replace one of the machines with a worse then the first one delivered now we have 3 37000$ paper weights
but again they can be re fitted for aprox 3600$ each to a level where we can start the table leveling process after that with tool changer software we can began to attack atc issues what a waste of human time energy and money is there any way we can let the world at large know about this chineeeeeeeeeeeese mouse trap
  #88   Ban this user!
Old 04-12-2010, 04:28 AM
asdasd is on a distinguished road
Originally Posted by Salty72 View Post
ATECHY
As you mentioned the wiring was all screwed up
Here is a copy of the E-Mail that was sent to me regarding the wiring
QUOTE"
the software I'm useing Mach3 this is what i used to wire it.
Hear is the Wireing for a 15 pin to 25 pin connector.
If you don't have home limit / prox switche's Ignore them.
The step and direction Opto-isolator's are wired backward's Lossen the screw's on Green conector's top of stepper box'es, pry the glue and wire's away from the Conector and reinstal them as listed below.
Do not conect the Prox/ home switch'es at this time.
This show's the 15 to 25 pin conection.
15pin conn. 25 Pin conn.
1. N/C 1. N/C
10. Black---------- 2. X Dir. CW +
3. White---------- 3. X Pls. CP +
9. Black---------- 4. Y Dir. CW +
4. White---------- 5. Y Pls. CP +
11. Black--------- 6. Z Dir. CW +
2. White---------- 7. Z Pls. CP +
5. N/C 8. N/C
12. N/C 9. N/C
13. N/C 10. N/C
8. Red------------ 11. X Home Switch DO NOT CONNECT WITH OUT READING
NOTE 1:
7. Green----------- 12. Y Home Switch DO NOT CONNECT WITH OUT READING NOTE 1:
6. Blue------------ 13. Z Home Switch DO NOT CONNECT WITH OUT READING NOTE 1:
14..N/C
15. N/C
17. N/C
18. - 21. N/C (Common, Gnd.)
14. Black---------- 22. Gnd. for Home Switch'es
15. Yellow-------- 23. X CP -, X CW -, Y CP -, Y CW -, Z CP -, CW - , ( All ganged together is fine.)
NOTE:1 The Home Switche's on this machine are being powered by 36 Volt Power
Supply
If you have home switches, disconnect the Power and Ground wire for them and power them from your computer 5 volt and Gnd.
The main power plug center pin is the Gnd for the machine It is not connected solder a proper size wire to it and Gnd it on Machine frame.
UNQUOTE"
Well as you can see this thakes care of some of my problems, and should help a few others if they are thinking of buying one of these machines
NOW< ! how do you ensure everything is square, the rails are parralell and the router will cut accuratley
hi, Salty72
do the yellow wires have a positive charge or negative charge?
thanks
  #89   Ban this user!
Old 04-12-2010, 05:29 AM
Salty72 is on a distinguished road
The yellow wires are the trailing edges of the pulses hence "CW-" the software can be configured with either (+ve) going pulse or (-Ve) going pulse, as a result if the yellow is tied low the pulse will go Hi.
from here open Mach3 and ensure the "trigger on" is set to (+ve) going pulse
hope this helps
  #90   Ban this user!
Old 04-13-2010, 12:35 AM
thanks Salty72, but my problem is that I actually don't have the chinese router
all i have is the cw250 drivers I guess what I need is the settings for mach 3 I hooked up the wires, but have no movement in any of the motors, one of them only stutters.
if anybody has the settings i would appreciated thanks
mayitoc@juno.com
  #91   Ban this user!
Old 04-13-2010, 05:11 AM
Just did a quick Google search and found this site
http://lib.store.yahoo.net/lib/webtronics/CW250.pdf
they have the pinout for the drivers.. \
let me know if you need more info
  #92   Ban this user!
Old 04-13-2010, 09:48 AM
cabnet636 is on a distinguished road
the keling site has the diagrams for most all the chinese drivers
James McGrew camaster x3, aspire software
www.mcgrewwoodwork.com
  #93   Ban this user!
Old 04-29-2010, 01:15 AM
thanks Salty72 for your help, I took the time to draw a diagram (since the manufacturer doesn't have the right info for the driver) with help from Luca and you this is how the inputs should be wired, also probotix has the settings for mach3 and the driver
Name:	cw250 driver.jpg‎
