Hi all,
I'm new around here and completely lost, i was surfing your forum for some time, but I'm confused dont know where to begin at all. I would much appreciate any kind of help if possible.
[For someone who doesn't know where to begin, it looks like you're jumping in with both feet...]
I would like to build 5 axis milling machine for creating architectural models from foam / wood / plaster. I have no experience in
CNC at all but from searching around I come across Doughty Drive plans and B/C drive. Would like to ask you what you think about that,
[I'd agree with the rest of the people who advised you to start small, and work up to this giant 5-axis thing. Surely you'd find some use for a 3-axis router about a foot or two in X and Y, and you'd learn a lot about all this when building it. Any mistakes you'd make would be relatively small ones, not big disasters. It would also help in making the plates and other parts for the ultimate machine.]
i dont mind spending extra money for a good build, but I cannot simply afford to pay for a commercial machine that cost over 10 000$.
[As was pointed out, you're unlikely to find anything like the machine you're describing for $10K or even close. You'd be lucky if building this thing cost that little.]
models i want to create range from couple of inches up to max 9 feet in one direction (flat decorative molding panels), later from models i would do silicone molds. I would need a good precision so the lines from the milling are not that noticeable.
[That's not determined by precision, but by how you set up the finishing passes. Assuming the machine really works, if you make the cuts very close together, you'll get a smooth result - it might take forever to run, be out of square, or the wrong size, but you won't see those lines.]
thank you in advance
