Results 1 to 3 of 3
Thread: Rye Router with Bosch CC100 Help!
    Aug 2011
    UK
    We have just installed an old Rye router with a Bosch CC100 controller, but have no manual or instructions. It was working at the previous owners factory, but we are not able to get it running. There is an "axis error" flagging on and an error code 50 showing and also a error code 35 "no machine reierence, send axes to reference" shows when we try to manually operate an axis. Any help would be welcome.
    Aug 2011
    Hi, I used to opperate a wadkin Router with a Bosch CC100 control panel, it's been 4 years since last using it, but if I remember corectly there is an ( over-ride Key on the control panel) that you turn to be able to operate manualy, you should then be able to turn the jog wheel to clear the axis error. Does the screen tell you which axis the error is in?
    Aug 2011
    Hi, Also try checking that all of your limit switches are clear of anything that might have tripped them!
  1. Code Transfer - Bosch CC100
    By martindugdale in forum Commercial CNC Wood Routers
    Last Post: 09-20-2011, 06:23 AM
  2. Newbie- Bosch CC100 tip/info needed
    By Jake-san in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-13-2009, 02:46 AM
  3. Drip Feeding Bosch CC100
    By Spike_TDI in forum Commercial CNC Wood Routers
    Last Post: 06-05-2007, 02:04 AM
  4. Problem with Bosch cc100 controller
    By yanjue in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 09-23-2006, 01:00 PM
  5. EMI-Mec w/Bosch cc100
    By joem5127 in forum General Metal Working Machines
    Last Post: 10-04-2004, 04:07 PM
