Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 09-11-2005, 06:02 AM
woodglass is on a distinguished road
SHODA NC516 Router Problem
When I power up a SHODA NC516 router, I get the following message on the CRT:
'NOT READY'
I can't find any info in the (available) manuals/documentation.
Any Ideas ?.
TIA,
woodglass...
Old 09-11-2005, 08:30 AM
ger21's Avatar
Is this a PC running DOS? Sounds possibly like a hard drive problem.
Old 09-11-2005, 03:41 PM
No, the router does not have a PC/hard drive.
woodglass...
Old 10-12-2006, 03:11 AM
nickjones111 is on a distinguished road
You don't say if the machine is new to you or if you are familiar with it. I assume it's got a Fanuc control. Usually you will get this message until you have referenced the machine using ZRN switch and + / - keys to send each axis to it's reference position. Holding down P Q and cancel whilst turning on the Power will reset the axis controls which sometimes helps in a situation like this. Good luck, Nick.
