Results 1 to 7 of 7
Thread: Upgrading dos machine
    Aug 2010
    I am looking at an older Digital Tool machine that runs in dos. What is involved in upgrading this machine to run in windows?
    Thanks!
    Registered rich909's Avatar
    Feb 2011
    U.S.A.
    re upgrading dos machine
    Hi Alan --
    I don't have any experience with Digital Tool machines, but you might want to take a look at a couple of threads that appear to be related. See this one on the Digital Tool 904:
    Digiital tool 904 ...or this one
    http://www.cnczone.com/forums/diy-cn...ne_router.html
    Both are pretty recent threads, and might put you in touch with others who share your plight.
    If the original DOS computer is with your machine it is unlikely that you can upgrade that hardware to run Windows because of the processor, speed, RAM, etc. The controller may also likely need to be upgraded for windows as well as all the control software. In any event you will probably need some details such as the model number, software versions (if any), to get more specific help.
    HTH.
    --Rich
    Dec 2003
    I have a couple of machines that run on DOS with DSP based motion cards, I much prefer to run them this way than windows.
    Do you know what controller the machine has?
    Oct 2007
    my first was a dos machine and i went about upgrading. generally all drive and motors are way older tech as well best to do it all not just the controller, mine had older 1/2 steppers and would not vcarce at decent rapids with out stalling, figure a start at 750.00 (min) a motor and 3500 for the controller plus board. rewire it as well other wise you will eventually
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com https://www.dropcam.com/p/PFmTOV
    Dec 2003
    In my case I retrofitted the machine with the DOS program and motion card, the servo motors and encoders were fine, I just upgraded the drives to newer torque mode type.
    Oct 2007
    i just purchased another one this am, will let you know
    Oct 2007
    alan i am picking mine up this week did you purchase yours
    1. Something Old, Something New..Upgrading An Old CNC Millrite
      By Too_Many_Tools in forum Knee Vertical Mills
      Last Post: 04-10-2010, 10:48 AM
    2. upgrading to X4 what to look for
      By timmydabull in forum Mastercam
      Last Post: 08-11-2009, 06:59 PM
    3. Upgrading
      By Captn_tyler in forum Smithy
      Last Post: 06-06-2009, 03:50 PM
    4. Need Help!- Upgrading from X to X3
      By tumchie in forum Mastercam
      Last Post: 01-03-2009, 04:50 PM
    5. Need Help!- Upgrading CNC controllers for an Anton Engelhardt CNC Metal Milling Machine
      By drosscr in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 11-16-2008, 07:47 PM
