Page 1 of 2 12 LastLast
Results 1 to 12 of 21
Thread: Spoil board cutter?
    Aug 2010
    Spoil board cutter?
    Does anyone have any recommendations on a spoil board cutter for surfacing the MDF spoil board on our AXYZ router? I would think it'd have to be pretty balanced, since the default spoil board surfacing program won't run at any less than 8000 RPM's. I've seen a couple of different models from Onsrud, and one from vortex tool, I'm just not sure what to go for.
    Thanks in advance.
    Oct 2007
    i use a standard 1.25 inch mortise bit,
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com https://www.dropcam.com/p/PFmTOV
    Mar 2003
    Shelby Twp, MI....USA
    If you don't mind spending the money, I'd get either the Vortex or the Amana. I'll have to check, but I think we have the Vortex at work. It's about 3" diameter, and we run it at 15,000 and 600ipm. Still takes 5 minutes to surface our 5x12 spoilboard.
    Registered cheetahcnc's Avatar
    Oct 2007
    I use an onsrud 1.25" 91-000 P84492. Surfacing the spoilboard makes the most dust you will ever see from your router
    Aug 2010
    Quote Originally Posted by ger21 View Post
    We ordered the vortex yesterday afternoon, so hopefully it'll work. The tool rep we go through didn't think it was a good idea to run it at a very high RPM, but he's got less experience with routers than I do lol.
    Quote Originally Posted by cheetahcnc View Post
    I believe it, especially since we mostly cut aluminum, but we have a dust collector that I can strap onto the spindle head to keep the dust down.
    Jan 2005
    I just ordered a Onsrud 91-000.
    I see 18K max RPM .125" Max cut
    What overlap or machining strategy do you use?
    I can just imagine the amount of dust it generated. It will be a good test of my Kent dust shoe and Oneida Mini Gorilla ;-)
    Dave
    Aug 2010
    Quote Originally Posted by dfmiller View Post
    Dave
    I think I just overlapped it by like 15% of the cutter diameter. I've only had need to do it once, and that was apparently in May, so it's been a while. Our router has a program right in it for planing the spoilboard.
    As for the dust, it wasn't bad. Our dust collector worked very well. I think it's an Oneida Gorilla, 3HP if I'm not mistaken. Wasn't a bit of dust that escaped.
    Jan 2005
    Thanks,
    I will have to either use Mach Wizard or VCarve to write a simple program.
    My dust collector is the little brother to yours. Only 1.5hp. I will be using a short hose. ;-)
    I would have guessed a larger overlap.
    Good thing I asked.
    Thank you.
    Dave
    Aug 2010
    Thanks,
    Good thing I asked.
    Thank you.
    Dave
    I didn't see much reason to have a very big overlap, depending on how much of a cut you're taking of course. I only took like 0.025" off the top of the board, so it wasn't much. And our dust collector piping must be close to 30 feet long to the router, plus 10-15 feet of flexible hose to run to the spindle. It's a pretty slick setup. Just wish I could quiet down that damn noisy vacuum pump!
    Jan 2005
    I think I have about 0.045" to take off. I will probably take it in two passes to understand how badly my table is sagging. I ran a dial around it yesterday and I think I have a 0.040" dip in the middle. I eventually will add another support under the table.
    I am not running Vacuum yet. I have a small pump that I might try out after I make a vacuum table. Mine is not an industrial router like yours is. Mine a little hobby one.
    New XYZ Gantry Kit
    I assume you are using a big pump and are just sucking thru the MDF?
    Dave
    Aug 2010
    New XYZ Gantry Kit
    Dave
    yup, pull right through the MDF. Works really well except when trying to hold down relatively small pieces.
    Jan 2005
    How big is your router table?
    How big is the pump?
    Dave
  • Page 1 of 2 12 LastLast
    1. What are you using for a spoil board cutter on your cnc router?
      By rodjava in forum DIY CNC Router Table Machines
      Last Post: 06-30-2010, 04:52 PM
    2. Surfacing the spoil board
      By Rickv100 in forum JGRO Router Table Design
      Last Post: 10-31-2009, 03:28 PM
    3. Need Help!- What is the purpose of a spoil board?
      By j_wizard in forum CNC Machining Centers
      Last Post: 10-27-2009, 10:18 PM
    4. spoil board fly cutter question
      By jrj5x5 in forum Camaster
      Last Post: 05-21-2009, 07:38 AM
    5. Newbie- Spoil Board
      By lfourtner in forum JGRO Router Table Design
      Last Post: 12-15-2008, 01:40 PM
