Results 1 to 2 of 2
Thread: HIGH-Z S-400
    Feb 2011
    uk
    HIGH-Z S-400
    I am a complete novice so please be patient with me.
    I am looking to cut holes and grooves in 4mm wood.
    The wood pieces will be 246mm x 246mm.
    So my questions at this point,
    1) Is a S-400 suitable for my needs?
    2) Can a beginner work with these machines, are they easy to program?
    3) Looking at the pictures of the machine I can't see how pieces of wood are held in position during cutting. Do I need to use a clamp or something?
    Cubikoman
    Jan 2009
    Latvia
    First - go for S-400/T version. It's faster and more productive.
    Second - buy a bigger machine than You need for now. Let's say S-720/T. In most cases as You start with one particular product You shortly face another, but - Your machine table is too small ;-)
    1. yes, You can do all You mentioned on respective machine.
    2. Together with machine buy VCarve Pro and dont take that ConstruCam they are offering - it's not forth of that. VCarve Pro is VERY easy to get a hands on.
    3. You 'll have to build a work table. Most popupal way - 3 sheets of MDF/HDF bolted together and faced flat by machine it self. Fast, sufficient, cheap way.
    Manual how to do that is available on manufacturers web.
  1. Just IN- High Precision, High Speed Bearings
    By mikeyg in forum Product and Manufacturer Announcements
    Last Post: 09-07-2009, 08:06 PM
  2. High voltage & high power servo drive design
    By Xerxes in forum Granite Devices
    Last Post: 08-22-2008, 10:24 PM
  3. High Torque , High Bandwidth Motor or Servo
    By mastabib in forum Benchtop Machines
    Last Post: 09-26-2007, 03:09 AM
  4. High speed spindle... how high?
    By jonesja2 in forum General Metal Working Machines
    Last Post: 06-04-2007, 08:18 PM
