Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
  #13   Ban this user!
Old 07-18-2005, 11:32 AM
scrap-happens is on a distinguished road
Mostly user error, like accidentally unplugging a live stepper and frying the board. Occasionally you need to make sure the machine is still square and true. It is easy to do with a v-bit and scrap of plywood. Just manually mark a line in the x and y direction and check with a square.
One of the biggest challenges with the machine is coming up with a way to mount the part. We found it very efficient to make jigs that use wedges and pins to hold parts. That way all you have to do is tap on a few wedges to install or remove a part and if you make a mistake you don't ruin an expensive bit.
Another problem we had was the rack and pinions get clogged with sawdust and will make it jump time. You just have to keep an eye on it and blow it out occasionally.
Also, the boom that supports the wires is crap. Once we removed it and installed IGUS track it was much improved. Hope that helps.
  #14   Ban this user!
Old 07-19-2005, 01:49 PM
Ravi is on a distinguished road
Thank Scrap-happens
  #15   Ban this user!
Old 04-09-2007, 07:45 AM
Joe Crumley is on a distinguished road
Ravi,
I would encourage you to consider Ez-router.com. This is a much more stable CNC than Shopbot. It cost less also.
I've owned both and the EZ is far ahead.
J
www.normansignco.com
