Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-13-2005, 08:29 AM
Jamf2's Avatar
Jamf2 is on a distinguished road
Biesse Rover 20 NC410
Has anyone retrofitted a Biesse machine?
We have a Biesse Rover 20 point to point machine that runs on NC410 programming by biesse. It's a okay program but I'm trying to get all are machines to run off of Bobcad20 and Mach 2.
Anybody ever change out a system?
What is possible? What you will!
Old 07-13-2005, 08:42 AM
ger21's Avatar
Does this have horizontal drilling spindles as well as vertical? ATC? I don't think you can program the drilling spindles with standard Gcode in Mach2/3? I could be wrong, though.
Old 07-13-2005, 09:07 AM
Jamf2's Avatar
Yes it does have both vertical and horizontal.
Old 07-13-2005, 09:19 AM
ger21's Avatar
Are the drilling spindles and router on the same Z-axis? You may be able to use M codes to turn on or drop individual spindles, and use G1 moves to drill. Programming in BobCAD to use the spindles might be tough. rewiring the machine to interface with Mach2/3 would not be an easy job either, I don't think.
Does the machine work fine right now?
Old 08-05-2005, 08:52 AM
Thermwood is on a distinguished road
Rover retro
We just brought a Rover 20 NC 410 on the floor for evaluation and are not sure we are going to retrofit it. However, we run a Thermwood C50 with Galil controller / Camsoft package and One CNC Mill XR for Cam.
WE recently added an air drill on the Thermwood and drive it as follows ;
Piggy back of on of our two Z axes, Fired with M codes using offsets to avoid crash between Z head and drill. In our code, the drill is basically a head driven on a common axis ; Router = T1, drill = T3, driven with all standard G codes. It really was rather easy to implement and works great.
Any tips on the NC 410 would be appreciated ....
Pierre
Old 07-06-2010, 01:56 PM
smal is on a distinguished road
Help me! Need electrical diagram of NC410.
Old 07-13-2010, 06:21 AM
battwell is on a distinguished road
i am in the middle of a mach3/ galil conversion. on biesse 335
its a very big job!
lots of programming work to do.
i will be offering a retrofit controller once completed, but it wont be cheap!
so much to learn, so much to pass on.
Old 07-15-2010, 07:44 AM
battwell, you have control NC410?
Old 07-15-2010, 11:22 AM
yes.(i think)
what do you need?
Old 07-16-2010, 01:38 AM
I need electrical diagram NC410. Or you can sell me your control NC410?
  #11   Ban this user!
Old 07-16-2010, 05:39 AM
sorry. i only have rt480 for sale (from my retrofit machine)
there is a 481 on ebay
http://cgi.ebay.com/CNI-RT481-CONTRO...item48385da501
dont think ive seen a 410
what is not working on your control?
biesse uk can be very helpful if you spend money!
  #12   Ban this user!
Old 07-18-2010, 06:45 AM
This shows my screen.
Rover CNC machines & ProEngineer Speling CNC Machining Centers 4 10-16-2008 09:36 PM
Biesse Machine and MeshCam - HELP nem3 GRZ Software- MeshCAM 11 09-28-2007 09:57 AM
Mars Rover Finds Life on Mars. Holy cow look at this WallCrawler CNCzone Club House 11 01-27-2004 03:15 PM
