Go Back   CNCzone.com-The Largest Machinist Community on the net! > WoodWorking Machines > Commercial CNC Wood Routers
Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here!
Old 07-08-2005, 12:05 AM
CamWest is on a distinguished road
Software for an older machine?
I work for a company that recently puchased an older Camtech. I believe the model number is 5/52. The software that is used to run the machine is called pcu, it is older dos software and is a little unfriendly to use. Is there any options to upgrading to newer software to run this machine. The computer(s) I can run this from are Windows2000 or WindowwsXP.
Old 07-08-2005, 10:02 AM
Al_The_Man's Avatar
You would probabally need hardware changes as well as software.
If it has one of the well known motion control cards in a PC slot, then you may be ahead in not having to purchase another. Otherwise there are a few PC based systems outhere to consider. Otherwise unless the company is still around with an upgrade then it will require a bit more than just a simple software installation.
I just googled them and I see they still operate out of Calgary, so not far from you.
Processor code for older printer controller??? thuffner3 Post Processor Files 4 07-27-2005 07:12 AM
Help Older CNC JR controller pinout for Mach III sandtoysrus Servo Motors and Drives 0 03-17-2005 02:14 PM
older fadal control ? tractdesign Fadal 11 01-08-2005 03:26 PM
Older Craftman LAthes? FXRocket General Metal Working Machines 2 11-10-2004 11:01 AM
Post Request - older Bostomatic 312 aiwnios Post Processors for MC 1 09-24-2003 03:08 PM
