| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| 4th Axis I'm curious, how does one add a powered rotary table to the controls. I'm toying with adding it to my new router mill to do engravings on round objects with a salvaged printer motor. Help. |
| What type of drives sre you using? If your set-up allows(hardware and software) you to have a 4th axis, then it is simply a case of add the hardware, tell the software it has 4 axis, oh yes and of-course all the necessary building/wiring ....integrating is always fun...
__________________ menomana |
| Could'nt I use y axis as a control on Mach2. ? Isn't it just a different way of looking at y axis. Like rolling it up instead of spreading it out flat? |
| If you are using Mach2 is already has axis' a, b and c which can be programmed as rotary axis. I think it would be much easier to use on of the rotary axis and just not use you y if you don't actually need the 4th axis. Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| 4th Axis Parallel Roughing | whiteriver | Visual Mill | 2 | 06-17-2007 12:10 AM |
| 4020 4th axis problems | little bubba | Fadal | 3 | 06-13-2005 10:08 PM |
| 4th Axis | UKRobotics | General Metal Working Machines | 7 | 03-19-2005 10:25 AM |
| Can 4th axis do offaxis undercuts ? | lesd | Visual Mill | 3 | 12-17-2004 07:27 AM |
| Reverse thinking on a 4th axis | whiteriver | Visual Mill | 1 | 03-03-2004 12:38 AM |
