Results 1 to 4 of 4
Thread: Multicam 3000 not communicating
    Mar 2008
    out of nowhere my machine cant talk to my PC. The communication manager says there is no problem and I can send a job from the PC to the router but I cant see any jobs from the router end.
    Could this be a network card issue? it seems to be sending and receiving packets so it should be working.
    Jun 2010
    Need Help! Multicam 3000 not communicating
    If you still have connection with the router.
    Which program to you use to communicate
    PSS
    Suite 4
    if you have PSS, right click on the Jobserver Icon, go to Program Settings and check to see if your file extentions in the boxes. File extentions should be
    Hpgl PLT
    CNC anc cnc
    Native ucj uc
    Binary bin
    if everything is there click the settings box and make sure it reads; c:/DNC or where ever your machine files are located.
    If everything is ok in those boxes....right click on the jobserver icon again, click on DNC and make sure the it reads c:/DNC or where ever your DNC files are located..
    In suite 4, right click on the suite 4 icon, goto settings and click onthe job folder tab and the root folder you should have c:/dnc in the box.
    Registered Boltz's Avatar
    Mar 2010
    What software handles the communications? Is it communicating over ethernet?
    -Jim Hart
    My main machine: Multicam MG series (MG101) with original Extratech H971 controller, Minarik servo motors, Electro-Craft BRU-series drives, 4KW Colombo. Let's talk Multicam!
    Mar 2008
    I use Suite 4 and after I went through everything again it worked even though I did not make any changes so either its an intermittent issue or ?
    Thanks for the ideas - hope it stays working.
  1. Need Help!- Multicam 3000 Umbra spindle
    By marcinito in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 11-05-2010, 12:46 AM
  2. Need Help!- CATIA V5 to MultiCam 3000 GCode
    By multicam3000 in forum Post Processor Files
    Last Post: 09-16-2009, 04:03 PM
  3. Multicam 3000 low airpressure error, please help
    By lukaspanic in forum Commercial CNC Wood Routers
    Last Post: 04-11-2008, 08:29 PM
  4. Multicam 3000 Nightmare
    By angelocmp in forum General Waterjet
    Last Post: 08-29-2007, 09:32 PM
  5. MultiCam 3000 error message
    By DRolph in forum Commercial CNC Wood Routers
    Last Post: 01-11-2007, 04:30 PM
