Page 4 of 4 FirstFirst 1234
Results 37 to 38 of 38
Thread: Multicam MT22
  1. #37
    Mar 2011
    Kazakhstan
    I used CorelDraw. Previously, everything worked fine, the lamps do not interfere, but I need to check. Give please link MCPservice, where I can ask for help.
    Thank you very much.
  2. #38
    Mar 2011
    Norway
    Quote Originally Posted by Glazman View Post
    Thank you for your reply. I have a Multicam MT22, it more than 10 years, the table size 60cm * 60cm approx. It worked through the program WDNC95, Windows 98. But the computer's hard drive crashed. Now installed Windows XP SP3. I downloaded the Internet wdnc95. Configure: 19200, and various customization options. And also in the properties of a computer set up 19200. The machine sees the files in the folder. Engraving is ok, but at some point Multicam makes a vertical or horizontal line, which is not in the file material to be thrown out because of this. Help me solve my problem, please. I do not know much English. I read the whole topic is difficult, perhaps that is not noticed.
    Hi Glazman.
    As suggested earlier you should first of all check for interference and also check your wire to the MT22. Is this happening on every job, or is this a fault on jobs over a certain size? Are there any other caracteristics to the jobs that fail -i.e. texts, circles etc.?
    What you also could check if nothing else works, is the 5.04VDC value between wire 131/132 (or they could be numbered 320/321 on different models). This is (on our machine) adjusted with a small meter on the smallest card in the cabinet. Adjust very carefully -if this voltage is out of range, you may experience unwanted stops etc. It should read 5.04 - 5.07VDC.
    Best regards
    Tony
  1. Need Help with MultiCAM
    By loyedp in forum Multicam Machines
    Last Post: 01-05-2012, 02:44 PM
  2. Need Help!- Multicam DNC problem
    By joanpim in forum Commercial CNC Wood Routers
    Last Post: 10-15-2010, 06:15 PM
  3. Multicam Driver
    By ironmountain in forum CNCzone Club House
    Last Post: 10-22-2009, 04:13 PM
  4. Need Help!- multicam MG 205
    By patrick kilby in forum WoodWorking
    Last Post: 11-02-2008, 02:00 PM
  5. Multicam 5-204-R
    By topdog in forum Commercial CNC Wood Routers
    Last Post: 05-21-2007, 12:57 PM
