Results 1 to 3 of 3
Thread: Recommendations on noise isolation solutions
    Oct 2009
    Israel
    Hi
    I am about to place a CNC machine in my garage.
    To keep the peace with my neighbors I am looking for a solution that will contain the sound to the confines of the garage.
    I will be grateful for recommendations on acoustic isolating materials and the geometry of the surface of such materials?
    Thank you
    Ariel
    Oct 2007
    if the garage is insulated you might add insulation board to the back of the door
    jim
    James McGrew CAMaster 508 ATC
    www.mcgrewwoodwork.com https://www.dropcam.com/p/PFmTOV
    Sep 2010
    Insolating the door is a good idea. I did that T my old house. One thing to note you might need to have the door springs adjusted. The added weight of the insolation can through off the balance. That is what happened to me.
    Anotheare idea, if it is a bench top cnc, is to build a case that goes around the machine. I have seen where others have done that. Put some kind of plastic glass on one or more sides then insolate the others. I think you will need a good dust collector attached to make this work.
  1. Need isolation PCB software??????
    By Burnit0017 in forum PCB milling
    Last Post: 06-09-2010, 04:05 AM
  2. LPT Opto isolation BOB
    By shulio in forum General Electronics Discussion
    Last Post: 03-11-2009, 08:01 PM
  3. MIE Solutions (www.mie-solutions.com) Manufacturing Software systems
    By MIE Solutions in forum Product and Manufacturer Announcements
    Last Post: 12-17-2008, 03:07 PM
  4. Need Help!- DO YOU HAVE TO USE AN ISOLATION TRANSFORMER
    By racer652 in forum HURCO
    Last Post: 02-29-2008, 11:00 AM
  5. PCB Trace Isolation - Minimum Track and Isolation
    By ahoodlum in forum General Electronics Discussion
    Last Post: 09-26-2006, 12:02 AM
