| Commercial CNC Wood Routers Discussion Commercial CNC Wood Router Machines here! |
| Hi Guys, I read this whole thread learning new things with every post. I also have a servo 3925 machine with all the axis on thompson rails and ballscrews on the x+y. I am a CNC rookie. My machine was seriously beat up in shipping. We had the machine crated and sent nearly assembled by freight truck. K2 did a decent job crateing the machine but a lazy driver litterally pushed it out the back of the truck. Absolutely brutal handling. With a little luck, the freight company may have bought a good portion of this machine for me. I have a couple questions.... How quiet should the ballscrews be? It seems that they are making a bit of "tinking" noise at 75 - 150"/min. Should the machine just make a "whine" noise when operating? I am not sure if the shipping damage is causing the extra travel noise. I lubed the ballscrews with lithium grease. I do NOT think the X or Y is bound at all, powered down I can spin the axis fairly easy by hand, even with the belt on. I can even push the carriage and the servo motors spins... I think the axis is free enough, but I am worried about the noise. The Z is dead quiet even though the lead screw is bent. Is the best method to ensure a flat base surface to simply routing a wood base flat? By chucking up a 1/2 end mill and making a zillion passes this will create a perfectly calibrated Z axis base plane. Is there a better way? I have the Hitachi 12V router and I am looking for a 1/8th collet without using the spacer collet in a 1/4 inch unit. Does anyone make a ope-piece (no adaptor) 1/8th collet? Will a Porter Cable or Makita work in a Hatachi? Using MasterCam and Mach 2, it seems that there is some kind of post-processor issue when completing a drilling sequence. It seems that after canning the drill cycle (G80), it starts to contour without lifting the z and initializing a rapid transit movement (G0). Any one have any tricks to fixing this issue? Right now it requires manually adding a G0 after every G80 to rapid jog to the start point of the contour cycle. Are most of you using soft limits? Or do most put micro switches at each end? I am sure I will have some more questions, thanks in advance for your information. Mark |
| I have a 3925 machine also and my ballscrews are pretty noisy also, Im not sure if they are suppose to be though. |
| Yes porter cable makes a 1/8 collet adapter. It isnt in any store you will need to order it from porter cable yourself, or a local homecenter can order it for you. And my machine makes all kinds of noise I have had my one for almost a year now with miminal problems. I had ken add a plasma table to my machine and he made me a holder for my plasma hand torch. You can chuck up a fly cutter to level your table real fast. |
| Hey guys, Same here. I was suprised at how noisy they can be. I did open mine up to clean them out and added 2-3 (I think 3) extra balls. They are3.15 mm and you might have some ball bearings you can cut to get the balls from. taus
__________________ Thanks, tauseef www.cuttingedgecnc.com |
| Beginner Questions | dfranks | CNC Plasma and Waterjet Machines | 6 | 06-12-2005 11:40 AM |
| Work has commenced, many questions | Tabor | DIY-CNC Router Table Machines | 3 | 09-21-2004 12:46 PM |
| Some Gecko 201 Questions | mikie | Gecko Drives | 3 | 08-10-2004 12:40 AM |
| Questions for starting and a formula ... | elenabux | General Metal Working Machines | 3 | 07-17-2004 07:54 AM |
| A few honest questions | HuFlungDung | CamSoft Products | 8 | 06-15-2004 07:24 PM |
