Need Help! Line too long error on wincnc controller
Results 1 to 9 of 9
Thread: Line too long error on wincnc controller
    Aug 2016
    Default Line too long error on wincnc controller
    Hello,
    I am a newbe to wincnc I used to work with komo routers with fanuac controllers
    but its been awhile. My setup is CAM TECH 52 SM with Enroute 3 and a wincnc controller.
    i purchase this second hand with no manuals. I have downloaded the manual and watched every
    YouTube video I could find. It has got me to this point. Which is the machine responds fine
    to all Gcode commands. I have found a couple of jobs that the previous owner left in the computer
    and they run fine other than the z axis. When I go the create my own job and import the file it gives
    an error message line too short. The Gcode files that I create are the same as the ones left in the computer. They start and end with the same commands.
    Can anyone out there give me any ideas on how I might fix this error?
    thanks
    Mar 2008
    Default Re: Line too long error on wincnc controller
    Can you post the line that produces the error?
    How about a screenshot of the actual error?
    Gary Campbell GCnC Control
    Servo Control & ATC Retrofits
    Aug 2016
    On wincnc it's line 1
    I have since used another program TPCWin software that came with my router that converts the file to an nc. Instead of tap. File and it will accept it and will run that file with no errors.
    My other problem is my z axis is all over the place. I need to learn how to set home positions absolute / local
    The machine will zero fine. I can touch the tool off to my work surface. Zero it and run the program. The z will not go to the proper depth. Most of the time it routes way above the work piece. (Gcode is correct)
    Thank you ISLAWW for your reply. Don't know if you can help me with the z
    The wincnc manual is so vague.
    Jan 2005
    Is the program setting a tool length from the tool table? Look for a G43, or G43.1.
    Mar 2008
    I was referring to the actual code that produces the error.
    Can you post the file?
    Aug 2016
    Quote Originally Posted by 109jb View Post
    The nc file that runs there is no g54 or g 43 in the code itself.
    It's specifies on the controller
    Attached Thumbnails Attached Thumbnails Line too long error on wincnc controller-image-jpg   Line too long error on wincnc controller-image-jpg
  7. #7
    Aug 2016
    Quote Originally Posted by islaww View Post
    Here are the screen shots of the tap. File that will not run.
    Attached Thumbnails Attached Thumbnails Line too long error on wincnc controller-image-jpg   Line too long error on wincnc controller-image-jpg   Line too long error on wincnc controller-image-jpg
  8. #8
    Mar 2008
    My guess is that your file path name has too many characters in it. Some of those older versions had a smaller limit than todays versions.
    Steps to test:
    Create a folder in the root (C
    Copy your tap file to that folder
    Open/load the file and see if it runs from that location
  9. #9
    Aug 2016
    That's it ISLAWW
    It will run the file now
    Thanks for the help
