Just wondering if there's anyone on the forums who's running Prima lasers? In particular Platino 1530? We've had some problems since we got ours and it would be nice to have others to bounce ideas off. For example, we had an issue with the $(MARKING) / $(END_MARKING)(0) function that would make the head lift off the surface 20mm for every marking operation. If there was a large amount of marking this made for a lot of wasted time. If the end marking z retract parameter was set to zero, it would lift up 20mm, but if it was set to >0 ( I forget the exact range that would avoid the 20mm standoff ) it would work ok but of course, we often wanted to avoid lift.
Problem solved eventually but it was a PITA because all the functions are commented in Italian and there's nothing in the manual.
